More performance?
Old Jan 4, 2006 | 12:10 AM
Markstang1969's Avatar
Markstang1969
Default RE: More performance?
ORIGINAL: bigblocked
you could buy my 429 block fresh from the machine shop !
Hmmmmmm. How much
Old Jan 4, 2006 | 12:13 AM
6mustang6's Avatar
6mustang6
ill trade you a 289 for it.
Old Jan 4, 2006 | 01:03 AM
Shifty101Easy's Avatar
Shifty101Easy
can someone explain to me how underdrive pulleys help that much? one of my friends briefly tried to explain but got side tracked and never finished....im looking for it online right now but am not coming up with much....what is it exactly and whats different about it?
Old Jan 4, 2006 | 01:14 AM
6mustang6's Avatar
6mustang6
They are just smaller or different sized pullies. What that does is, gives back some of the power they rob from the engine, but like i said, it can affect water pump and alternator performance.
Old Jan 4, 2006 | 01:18 AM
Dan66's Avatar
Dan66
ORIGINAL: slickman
...I have a stock 289 with a Holly 600...I would like to up the horse power and torque.
What are some things I can do on the upper end to give it some more HP and that snappy throttle response????
You've got too much carb, plain and simple. Move down to a 500 cfm Edelbrock. Problem will most likely be solved right out of the box.
Old Jan 4, 2006 | 08:39 AM
slickman's Avatar
slickman
Yup, its on the way. The Edelbrock 500 should be here Thursday.. I'll give you guys an update after I install it this weekend. I'm hoping it solves the throttle responce too.
ORIGINAL: Dan66
ORIGINAL: slickman
Old Jan 10, 2006 | 06:10 AM
beanutoo's Avatar
beanutoo
i just got me a 500cfm edelbrock. im going to install it this weekend. i have a 289. people have told me this is the right size for my car. but would it be find when i install headders? also whould stright pipe with flowmaster be ok or should i do the x on it??. im also planning on changing the heads and cams later in the futer so would me 500cfm be ok?? also which headders would you guys recommand? headman headders or hookers. thanks
Old Jan 10, 2006 | 03:11 PM
bigblocked's Avatar
bigblocked
headers i would go with 1 5/8 tubes i prefer hooker but have no specific on wich would be better.exhaust i would at least do a h-pipe set up with 2" exhaust witha set of good mufflers flow master ,magna flow or along that lines.for your carb if you feel its not enough after you have done this go to a 600 and play with the jetting till you get the results you want. Remember to have fun wi'll your doing it thats what is all about.driving the car is only half the hobby brother.
jwog666
Dec 27, 2021 08:09 PM
Dokilar
15
Oct 16, 2015 08:13 PM
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
