Carb Identification
Old Jan 2, 2006 | 12:25 PM
AFSarge's Avatar
AFSarge
Default Carb Identification
My 68 Mustang has a Holley 4 barrell carb on it. I am trying to find out how to identify the size of it 750cfm or what. I have heard a lot of bad things about holley carbs and want to get an Edlebrock. Can any one help. Thanks
Old Jan 2, 2006 | 12:52 PM
bvi steve's Avatar
bvi steve
Default RE: Carb Identification
The easiest way would be to look in a summit catalog. They have a lot of pictures to help you. Narrow down the serise then go by type of float bowl, choke, number of accelorator pumps and kickdowm linkage. That should get you close. Check the throttle plate size also. Some Holly carbs have a "list # stamped on the base or choke housing.
Hope that helps.
Old Jan 2, 2006 | 01:56 PM
69boss429's Avatar
69boss429
Sarge, for a quick check,look on the front of the choke airhorn for a 4 digit number. If is stamped 1850, its a 600 cfm. If you learn how to adjust and tune your Holley you will find it to be a great carb.
Old Jan 2, 2006 | 02:52 PM
AFSarge's Avatar
AFSarge
The only 4 digit number I found on the air horn is 1339. So far no luck on finding out what it means.
Old Jan 3, 2006 | 11:13 PM
Silver Ponys's Avatar
Silver Ponys
Go to holly.com and look in the tech section they have every carb listed there
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
Sminemann
Sep 17, 2015 09:24 AM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
jaiidutch
Sep 14, 2015 10:29 AM
