4.75 backspacing what does it mean
Old Jan 10, 2006 | 07:03 PM
66ckurt's Avatar
66ckurt
Default 4.75 backspacing what does it mean
i am about to buy a set of 17 " TT2s and everyones says u need 4.75 backspacing for them to fit what does this mean im guessing it can be spacers because they are measured in inchs and 4and 3/4 inchs is massive.
thanks
kurtis
Old Jan 10, 2006 | 07:17 PM
DARKON's Avatar
DARKON
Default RE: 4.75 backspacing what does it mean
It means that there needs to be 4 3/4" space between where the lugs connect to the inside (back) of the wheel.
Backspacing is normally a function of the wheel's fabrication. However, spacers can be used to compensate.
Old Jan 10, 2006 | 07:30 PM
66ckurt's Avatar
66ckurt
oh so its basically the thickness of the center of the rim were the bolts connect to?
Old Jan 10, 2006 | 08:38 PM
Markstang1969's Avatar
Markstang1969
ORIGINAL: 66ckurt
No the distance from the back to the hub. Different wheels have different "offsets". How "deep" in the wheel the hub center is.
Old Jan 10, 2006 | 09:01 PM
66ckurt's Avatar
66ckurt
so i need a positive 4.75 for my 17*8 ?
Old Jan 10, 2006 | 09:09 PM
Markstang1969
Backspace is measured from the back of the wheel.
Offset is measured from the center:
This page may explain better:
http://www.rsracing.com/tech-wheel.html
Old Jan 10, 2006 | 09:33 PM
66ckurt's Avatar
66ckurt
i got it now thnx for your help
Old Jan 11, 2006 | 01:09 AM
Markstang1969
YW
JoeyD
Feb 21, 2006 06:04 PM
fairlane292
Dec 27, 2005 12:39 PM
mike s 95
Dec 4, 2005 10:31 PM
SNORX302
Nov 18, 2005 10:52 AM
matacemat
Mar 18, 2005 03:03 AM
