66 Stalls When Stopping
Old Jan 31, 2006 | 05:26 PM
  #21
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: 66 Stalls When Stopping
Completely rebuilding the carb isn't a whole lot more time consuming than replacing the jets. Just for grins......how old is the gas? If it is old enough, it will cause the engine to spit and die. Ask me how I know.
Old Jan 31, 2006 | 06:39 PM
  #22
jimsz's Avatar
jimsz
Ok, I'll bite, how do you know?
Actually, the gas is several months old since the weather here has been raining for a couple months so the car hasn't been driven much. As well, the tank is getting near empty, water in the tank from condensation?
Old Jan 31, 2006 | 11:26 PM
  #23
Zurn's Avatar
Zurn
hmmm, gas will "gel" up given enough time and make things kinda clogged up. Could be your problem. Try some STP fuel line cleaner or a similar product. also fill her up with good fuel.
Here in So. Dak. the gas of choice to improve the oxegen content is gasoline with 10% ethanol. If that is available try a tank full of that as the alcohol makes a nice sticky gas solvent. I would not run more than the one tank of it though as it may also not be condusive to the rubber pieces in your fuel system. [8D] The alcohol will also help absorb any water in your fuel tank.
a good carb cleaner would be a cheap start.
Old Feb 12, 2006 | 12:18 PM
  #24
jimsz's Avatar
jimsz
It looks like I may have found the problem.
It does appear there is a vacuum leak. The throttle shaft does move around somewhat and when held in a certain position on each side of the carb, will allow the car to idle properly, even when put into drive. So, most likely, the soft brass bushings in which the throttle shaft is held are worn out and air is getting in there.
Solution 1: rebuild the carb and replace the throttle shaft bushings.
Solution 2: get a new Holley carb and sell the Fomoco for rebuild.
Old Feb 12, 2006 | 01:25 PM
  #25
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: jimsz
Sounds like you found the solution. Congrats! The reason I know about bad gas and its' effect on an engine, is that I stored my 65 for 10 months out of the year, and after so many years of this, the gas went south. It acted just like your description, so that is why I suggested maybe you needed to change the fuel. But, that wasn't the problem afterall. I would rebuild the Motorcraft carb. I am not a big fan of Holley carbs, but that's just me.
Old Feb 12, 2006 | 02:07 PM
  #26
jimsz's Avatar
jimsz
I wouldn't mind just rebuilding the carb but I'm worried that rebuilding the bushings is beyond my scope.
After reading the vendor bashing thread on Mustangs Unlimited, I ran across the ponycarburetors.com site and it appears I have an Autolite 4100 - heres what they have to say of this carb:
This is the finest four-barrel carburetor that has yet to be made by anybody. In performance, reliability, and fuel economy it is simply state-of-the-art. It will "blow away" anything that holley has yet to make.
Has anyone dealt with these guys? I wouldn't mind simply replacing mine with a rebuilt and selling them my core if what they say about this carb is true.
Old Feb 12, 2006 | 03:37 PM
  #27
jimsz's Avatar
jimsz
Which are the replacement carbs from Holley and Edelbrock for the Autolite 4100?
Old Feb 12, 2006 | 06:40 PM
  #28
6mustang6's Avatar
6mustang6
There are not really any replacement carb.... if it is the right flange for them, they should bolt up and run. If i was you, i'd send yours to pony carbs, and let them rebuild it, or buy a rebuilt one, from them. Glen(soaring) swears by them. Is that what you have on yours Glen????
Old Feb 12, 2006 | 08:42 PM
  #29
valley firearms's Avatar
valley firearms
Go to Pep-Boys and buy a new Holley 570cfm. They are the easiest to work on and adjust. You can adjust the floats without tearing the top of the carb off. They are just as easy to rebuild. Sorry boys, just my opinion.[8D]
Old Feb 12, 2006 | 08:47 PM
  #30
slickman's Avatar
slickman
Go get yourself an Edelbrock 500.....
cr620
Oct 3, 2022 10:18 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
Dathan
Oct 5, 2015 05:52 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
