clutch fork spring
Old Jan 16, 2006 | 04:54 PM
overdrive's Avatar
overdrive
Default clutch fork spring
I'm restoring a 66 convert. There's a return spring on the clutch fork. Where does the front of the spring hook? Thanks.
Old Jan 16, 2006 | 05:23 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: clutch fork spring
Look just a tad above the upper contol arm where it bolts to the frame, and you will see a slot there for the spring.
Old Jan 16, 2006 | 05:40 PM
overdrive's Avatar
overdrive
You're right. I found it with your help. A slot and also a hole for the end of the hook. Thanks again. It wasn't hooked there before, but I could tell it was wrong.
CS2007
Jun 25, 2019 09:45 PM
Thunderball
15
Nov 22, 2015 11:49 PM
mungodrums
Sep 28, 2015 10:54 PM
junior04
Sep 28, 2015 10:53 AM
