strange engine problem
Old Jan 24, 2006 | 04:54 PM
Silver Ponys's Avatar
Silver Ponys
Default RE: strange engine problem
Take your battery to a auto parts store and have them do a load test on it. It could be you have a shorted battery
Old Jan 24, 2006 | 05:08 PM
michaeldoggrell's Avatar
michaeldoggrell
whats a shorted battery ? and how can it get shorted ?
Old Jan 24, 2006 | 05:33 PM
Soaring's Avatar
Soaring
I ♥ Acer
One of the cells in the battery may have gone bad, and the battery is shorting out internally. Also, you may have voltage once you charge the battery, but there will be very little cranking power. Take it and the alternator to a parts place and have them both cheched.
Old Jan 24, 2006 | 07:57 PM
6mustang6's Avatar
6mustang6
YEP, my impalas battery did the same thing. It'd start up one minute, and not the next, lights be cutting on and off, and all kind of wierd stuff.
Old Jan 25, 2006 | 02:19 PM
michaeldoggrell
well guys
it aint the battery.
Replaced it today with a new one.
Turned the ignition, all i hear now is some noise coming from the starting relay
Old Jan 25, 2006 | 02:27 PM
Soaring's Avatar
Soaring
I ♥ Acer
Again, check all your connections. If everything is clean and tight, replace the starter relay (Solenoid). And, while you are at it, replace the Voltage Regulator. Did you have the alternator checked? How did you know the battery was shot? Did you have it checked along with the alternator?
Old Jan 25, 2006 | 04:06 PM
RSRXION's Avatar
RSRXION
Check your starter solenoid by jumping across the terminals with an insulated screwdriver. Turn the key to the "on" position and using the screw driver blade, make contact from the battery side of the solenoid to the smallest connector nearest the front of the car. THIS MUST BE DONE WITH CAR IN NEUTRAL OR PARK. It is definitely going to spark a little on contact but don't be alarmed. When you do this, does it crank ? If so, the solenoid is bad and it needs replaced. less than 20.00 at any parts store. If it still doesn't crank, check your ground cables where they meet the engine and body and take a quick look at your starter connections. Good luck, Dean
Old Jan 25, 2006 | 07:02 PM
the dit's Avatar
the dit
Like RXRXION said, Sounds like a ground problem if the battery was OK. If you replaced the negative terminal already it is probably where the egine is supposed to be grounded to the firewall.
Old Jan 30, 2006 | 06:13 PM
michaeldoggrell
Ok guys problem is resolved by changing the following items:
- cable from solenoid to starter
- ground cable from dynamo to engine
- ground cable & location from battery to engine
- cleaned up the contacts on the solenoid
thx for the info!
Old Jan 30, 2006 | 06:31 PM
Soaring's Avatar
Soaring
I ♥ Acer
Ain't it fun to have things work again?
