you mean hit the window? thats better then haveing a cheap sheet metal door cutting you in half.
Your head would break the window and keep going, snapping your neck. Unless you were hit on the driver side, I guess. Either way, you figure it out and then I'll take a look.
does that go on top of your current gas tank or totally replace it???
I've seen the top half of the original gas tank cut off and removed, and the fuel cell secured down inside the remaining bottom half. Looks factory from underneath. I don't know just how its done though...
