Wondering??
Old Feb 9, 2006 | 12:50 PM
lonos_new_curse's Avatar
lonos_new_curse
Default Wondering??
I have two questions regarding a mustang I am looking at:
1. How tough is it to repair a dent in the rear quarter, right on the ridgeline?
2. The driver's side front sits noticeably lower than the passenger's side. There isn't nearly as much clearance between the tire and the fender. Should I be worried, and what could this be caused by?
Old Feb 9, 2006 | 01:59 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Wondering??
Check to see if you have a broken spring or something on the driver's side. I'll leave the body queststion to the experts, but I think the ridge line would be a difficult repair. Might want to leave that to the pros.
Old Feb 9, 2006 | 02:06 PM
ideal_mustangs's Avatar
ideal_mustangs
Check too on the spring, someone may have left some spacers in one side or something like that
Old Feb 9, 2006 | 02:07 PM
lonos_new_curse
Thanks for the heads up on the spring. If it is a spring, I would feel comfortable changing it. The ridgeline concerns me, only because I don't think it can be pulled out easily.
Old Feb 9, 2006 | 02:11 PM
Soaring's Avatar
Soaring
I ♥ Acer
Also, check the upper and lower control arms.
Old Feb 9, 2006 | 02:25 PM
daver's Avatar
daver
Check your balljoints, I had this problem and it turned out to be that. The passengers was collapsed er somethin.
Old Feb 9, 2006 | 04:00 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Ball joints affecting ride height? Never heard of that one. If you could post some pics of the dent it would be easier to assess.
Old Feb 9, 2006 | 10:22 PM
dcohen's Avatar
dcohen
If its not a huge crater dent then i would just fill it with body filler and smooth it out
lincolnshibuya
Dec 8, 2015 04:37 PM
Dokilar
15
Oct 16, 2015 08:13 PM
fastbackford351
Oct 1, 2015 12:24 PM
Sixer4Life
Sep 29, 2015 07:03 PM
lmurf60
Sep 24, 2015 10:07 PM
