posi traction
Old Feb 9, 2006 | 10:42 PM
KBunny's Avatar
KBunny
Default posi traction
Hey I was just wondering how much I should expect to pay for a used posi traction setup? Im needing to do some work on my axle that requires opening it up and as long as it is open I would like to put something in thats better than the stock one wheel wonder.... but im on a budet so thats why I was going to go for a posi and not lock wheel or lsd or anything fancy...
Old Feb 9, 2006 | 10:50 PM
Shifty101Easy's Avatar
Shifty101Easy
Default RE: posi traction
can you throw a clutch pack in an open rear end and it be posi?
Old Feb 9, 2006 | 10:56 PM
KBunny's Avatar
KBunny
well I dont need anything very radical and dont plan on getting gobbs of power out of my ride but if I punch it I want more than just one wheel spining.... so if all I need is a clutch pack then how much are they? (I dont know to much about rear ends yet so bare with me)
Old Feb 9, 2006 | 11:48 PM
Shifty101Easy
yeah, thats all i want too.... (same boat)
someone help...?
Old Feb 10, 2006 | 02:17 AM
mlitz's Avatar
mlitz
OK there are two ways you can go cheap and expensive... they both do the same thing and to tell you the truth i don't know the difference.... so remember you get what you pay for....
http://www.detroitlocker.com/DEZ.htm
http://www.detroitlocker.com/DL.htm
Old Feb 10, 2006 | 03:20 AM
KBunny's Avatar
KBunny
Those are nice and I say the fallowing with out trying to offend you but..... that doesnt answer my original question..... how much should I expect to pay for a used posi traction system (I know someone who might have one and if he does I want to try and get it off of him at a fair price for both of us)?
Old Feb 10, 2006 | 03:48 AM
Shifty101Easy
thats no good for street use really though? doesent it start making all kind of noise and really put strain on it whenever you go around a corner?
wouldnt we want limited slip of those?
....that is...if u can simply just throw it in there and bolt it back up and thats it....seems too easy though...
Old Feb 10, 2006 | 01:01 PM
THUMPIN455's Avatar
THUMPIN455
Check Ebay, I have a freind who is selling a 9" posi for $200. I doubt you have a 9" rear though, if you do I can hook you up. A new posi will run about $400 and you cant just add clutches to an open diff. Maybe if you are a machinsit and have alot of time on your hands you could figure out a way to do it.
Detroit Lockers dont hurt anything when they turn, they do make a clicking noise but its not like the whole car is going to fall apart from using one. They sound similar to a CV joint gone bad in a front drive car.. click click click click etc...
Old Feb 10, 2006 | 02:17 PM
Shifty101Easy
i found an article, and i think i understand how differentials work.
looks like they just added the posi gear pieces to this open differential and its now posi....seems relatively easy and straight forward.
http://chevyhiperformance.com/tech/e...d/0506ch_diff/
Old Feb 10, 2006 | 02:27 PM
Shifty101Easy
http://store.summitracing.com/defaul...9&autoview=sku
you could put that in your existing equipement and it would be posi right? that would work for a street car in other words....?
