need blinker fluid!
Old Feb 14, 2006 | 07:32 AM
66rustang's Avatar
66rustang
Default need blinker fluid!
We're attempting to get the turn signals to operate in our 66 coupe. We replaced the silver canister looking relay under the driver dash, and that did not fix the problem. Where else is there a relay or another place to look for? (the more detailed the better) Thank you!
Old Feb 14, 2006 | 08:49 AM
gta289's Avatar
gta289
Default RE: need blinker fluid!
first thing i would do is check all the bulbs to make sure they are being grounded to there housings, ie: rear tailights etc. If one is not making contact, it wont continue the circuit, and therfore wont give you turn signals. Check them all and let us know
Old Feb 14, 2006 | 11:40 AM
Soaring's Avatar
Soaring
I ♥ Acer
After checking all the connections, take the switch itself out and inspect it for wear. If worn, or has broken soldering connections, replace it with a new switch. And while you have it out, use a multi-meter to check for 12 volts coming in. We also have some wiring diagrams in the FAQ section for you to use to trace down the problem.
Old Feb 18, 2006 | 07:16 PM
66rustang's Avatar
66rustang
the bulbs work, as the brake lights work fine, when the turn signal is used, the back tail light goes out. where is the switch located?
Old Feb 19, 2006 | 12:39 AM
gooziman's Avatar
gooziman
Sounds like you do need a new switch. That's what happened with my '68. Hit the turn signal and the brake lights went out. A new switch fixed the problem. The switch is in the steering column underneath the steering wheel. Pretty easy fix. Good Luck.
Old Feb 19, 2006 | 09:20 PM
66rustang's Avatar
66rustang
so does the steering wheel need to come off or is there an easier way to get to it?
Old Feb 22, 2006 | 09:36 PM
66rustang's Avatar
66rustang
anyone?
Old Feb 22, 2006 | 10:00 PM
Soaring's Avatar
Soaring
I ♥ Acer
You will need to take the steering wheel off to get to the switch. If you look at the picture of mine, the turn signal is on the left of the steering wheel, and after you get the wheel off, the collar will come off to expose the switch.
Old Feb 22, 2006 | 10:07 PM
SpudRacer's Avatar
SpudRacer
Before you tear your switch out, I encourage you to try something else first. I had the same problem with my 66. It turned out to be the connectors at the rear tail-lights. Try turning on the turn signal, then open up the trunk and start wiggling first one, then the other of the electrical connectors where they attach to the turn/brake housing. These fail often, and can be purchased at most parts stores. Once I replaced mine, the turn signals have given me no more problems.
Tom
jwog666
Dec 27, 2021 08:09 PM
Thunderball
15
Nov 22, 2015 11:49 PM
wraith777
Sep 28, 2015 10:49 AM
fastbackford351
Convertible Tech
Sep 27, 2015 06:51 AM
Sep 25, 2015 06:42 PM
