Spark plug wires
Old Feb 14, 2006 | 04:59 PM
lonos_new_curse's Avatar
lonos_new_curse
Default Spark plug wires
When assembling a custom set of plug wires, how much of the wire core should be left exposed at the cut?
Old Feb 14, 2006 | 05:41 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Spark plug wires
The directions that come with the wires should tell you, but I would think 1/4 to 1/2 inch. It would need to fit well into the slot of the metal thing.
Old Feb 14, 2006 | 06:55 PM
lonos_new_curse
Thanks Soaring---I was using about 1/4 of an inch, and didn't seem to want to stay back behind the connector. I didn't know if I could go much longer than that. 1/2 inch worked much better. Still have the buzzing sound in the speakers though.
Old Feb 14, 2006 | 07:25 PM
Soaring's Avatar
Soaring
I ♥ Acer
Still have a buzzing radio, huh? Look at your alternator, and see if it has a condensor (noise suppressor) attached to it. It should have, so get one if it doesn't. Here is a pic of mine. You will see the little round condensor that looks just like a condensor that goes into your points system in the dizzy.
Old Feb 14, 2006 | 08:51 PM
lonos_new_curse
Bingo!!! No Condenser on the alternator. Is install pretty straightforward?
Old Feb 14, 2006 | 10:02 PM
lonos_new_curse
Which is more effective? Installing the condenser on the Alternator, or the VR? As for the Alternator, is just a matter of mounting it to one of the posts, and hooking the wire on one of the other posts?
Old Feb 14, 2006 | 10:19 PM
Soaring's Avatar
Soaring
I ♥ Acer
Here are pics of mine I just took. I've had a few brewskies, so they may not be perfect. Follow my finger to where it connects.
BOB ROME
Jul 26, 2023 01:54 PM
jwog666
Dec 27, 2021 08:09 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
lmurf60
Sep 24, 2015 10:07 PM
