under trans tunnel...
Old Feb 16, 2006 | 06:13 AM
mustangdemon01's Avatar
mustangdemon01
Default under trans tunnel...
I cant find that piece that connects the two frame rails in the trans tunnel in my NPD catalog....is this one of those hard to find items? Also is it the cross member that the frame rails weld to in the front to be aligned? Ive been tempted to rip out the whole front frame rails(with everything including aprons) but figure i can use the old for measurments and such. Im also concerned about the trans tunnel itself...I was thinking i could save it but it is rusted through along the side near the top half (towards the firewall) and on the slope part a little. The rest of it seems to be okay towards the rear....is it wiser to just fix it up with sheet metal or just get a full piece floorboard(because floors are rusted through)? I know those LH and RH floors come up on the side towards the hump but i dont know if that will be enough.
Thanks!
Old Feb 17, 2006 | 02:36 PM
mustangdemon01
Default RE: under trans tunnel...
[sm=feedback.gif]
Old Feb 17, 2006 | 03:52 PM
Soaring's Avatar
Soaring
I ♥ Acer
Snap a pic of your firewall and tunnel so we can get a better idea of what you are talking about and how much damage you are facing.
Old Feb 18, 2006 | 03:09 AM
mustangdemon01
I got the pics...the part i am asking about is the one with the arrow...is mine still usable, if not where do i get this part? I heard that the frame rusts from the inside out and the other parts are being replaced. The last pic is of the trans tunnel and the circled area is where the rust holes showed up while i was wire wheeling.
Thanks.
[IMG]local://upfiles/19323/D164E533AECF4713A6EFB700A6EA764A.jpg[/IMG]
Old Feb 18, 2006 | 12:11 PM
351foxstang's Avatar
351foxstang
itwould be more money for the full floor pan. but it would make it ALOT easier. with your trans tunnel as rusty as it is, the full floor would probably be your best bet.
as for the crossmember that connects the two floor supports it would be alot easier to tell if it is bad or not once you remove the floor. i thought mine would be very rusty, but once i got it out of the car it wasn't too bad at all.
Old Feb 18, 2006 | 12:21 PM
c130nav's Avatar
c130nav
Check these out
http://www.laurelmountainmustang.com/index-1024.htm [ part # 3610] $54.95
http://carpartsdiscount.zoovy.com/c=...product/528724 $47.95
http://www.virginiaclassicmustang.co...hop/search.asp $56.95
I found these few sites. Hope they help. Could not find anything either in NPD catalog.
Old Feb 19, 2006 | 04:38 AM
mustangdemon01
Hey thanks guys... i cant cut the floor just yet....i figure i need the car to have some support and the frame isnt doing a good job of that....i ordered the frame rails from NPD last week...im moving steadily but im eager to get some real work done.
Old Feb 19, 2006 | 09:37 AM
1965MustangFastback's Avatar
1965MustangFastback
I agree you should buy the one piece floor, brace the door jambs before you decide to cut it out!
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
wraith777
Sep 28, 2015 10:49 AM
2poor4u2
Sep 26, 2015 11:08 AM
97SN95GT
Sep 13, 2015 09:45 PM
