CAMS.
Old Feb 17, 2006 | 09:41 PM
ADRIAN1's Avatar
ADRIAN1
Default CAMS.
i have a 1965 coupe with a 289 that has a 4barrel carb, edelbrock intake manifold and 2.5 flows. i am thinking about getting a cam but im not sure what to get. what do you guys suggest? remember that i want a daily driver with good idle but i also want some horsepower
Old Feb 17, 2006 | 11:43 PM
THUMPIN455's Avatar
THUMPIN455
Default RE: CAMS.
SUM-K4400 Summit Cam and Lifter Kits
Cam and Lifters, Hydraulic Flat Tappet, Advertised Duration 262/ 272, Lift .448/ .472, Ford,Small Block/ 351W,...
Monday $79.95
Work pretty good, still have decent vacuum, idle ok with a bit of a chop, might get by with stock springs MIGHT, and it would have more power than the stock cam does. Ford was always conservative on cams.
Well something about that size would work..
Old Feb 18, 2006 | 04:12 AM
mg's Avatar
mg
Default RE: CAMS.
I got a 73 mustang and it has a 351C and i just put a cam in it. The things to consider daily driver, but you still want that authority behind it!! so i got a cam from summit racing it has about an 8th inch lift. PLZ rem to break in the cam right so you dont mess the lifters or the lobes on the cam..its happened to me before.
Old Feb 19, 2006 | 01:57 AM
tinman's Avatar
tinman
Default RE: CAMS.
Buy quality if you are even going to mess around with it.
Comp Cams 268H should do it for you. Get cam, lifters,springs while you are at it........
BTW, new timing set not a bad idea while you got the car apart....
Old Feb 19, 2006 | 02:14 AM
65GTin GA's Avatar
65GTin GA
Default RE: CAMS.
You have a Performer 289 intake? I would match it to the Edelbrock Performer Plus cam kit - I did. Works well, idles nicely, runs plenty quick. And Do follow the break-in requirments no matter what you pick.
[IMG]local://upfiles/3913/03CA927788C04910A6FD87025E000DEA.jpg[/IMG]
Old Feb 19, 2006 | 02:59 AM
ADRIAN1's Avatar
ADRIAN1
Default RE: CAMS.
thanks to everyony who helped me out!!
uberstang1
Dec 7, 2017 07:10 AM
GT4POiNT6
Jan 8, 2006 11:02 PM
DILO2001GT
Oct 2, 2005 05:36 PM
Richman
Apr 24, 2005 12:44 PM
S_man_9
Aug 13, 2004 04:05 AM
