351C heads on 351W
Old Feb 19, 2006 | 01:38 PM
pwhit's Avatar
pwhit
Default 351C heads on 351W
Just was not sure if they would fit and if there is any benifit to them if they do.
thanks,
pwhit
Old Feb 19, 2006 | 02:28 PM
pwhit's Avatar
pwhit
Default RE: 351C heads on 351W
Sorry guys I threw a question out prior to doing my own research. I found out that it is not an exact swap and you need a different intake to match up. So I don't believe that I will use 351C heads.
Thanks and sorry for the question,
pwhit
Old Feb 19, 2006 | 03:29 PM
BillyBobJoe's Avatar
BillyBobJoe
well, if you do it, congrats...you've got a Boss 351 (or so i thought)
Old Feb 19, 2006 | 04:50 PM
69mach1377's Avatar
69mach1377
Pretty close...try a Street Boss 377! See my sig and link.
Old Feb 19, 2006 | 05:00 PM
valley firearms's Avatar
valley firearms
If Ford put Cleveland heads on a windsor block and called it a 302 BOSS, has it grown since 1970?
Old Feb 19, 2006 | 05:12 PM
pwhit's Avatar
pwhit
OK so is it worth doing? From what I read the perfered street heads would be the 2v heads. I would need the proper intake, is there any other modifications to the heads or anything that I would need to do or do they just bolt on?
pwhit
Old Feb 19, 2006 | 11:14 PM
THUMPIN455's Avatar
THUMPIN455
The water jacket holes need to be drilled so they match, and the pistons are different.. Do a google search on CLEVOR and you should be able to find the info you need.
FYI a BOSS351 was a Cleveland engine with 4V heads and an adjustable valvetrain, its the only Cleveland head other than the BOSS302 to get adjustable rockers.
Also did you know: The 4V Clevelands and the 2V Clevelands used the same cam profile 71-73...
Old Feb 20, 2006 | 12:08 AM
Nut Case's Avatar
Nut Case
Check out http://www.chiheads.com. They have some pretty impressive 351 Clevor combs. Also, they have a clevor intake to match. I would really love to build a stroked clevor for one of my Mustangs.
mustangheaven
Jan 3, 2016 11:20 AM
mustangheaven
Oct 7, 2015 10:23 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
Drastang
Sep 30, 2015 03:48 AM
mustangheaven
Sep 29, 2015 11:00 AM
