stuck heater switch
Old Feb 20, 2006 | 05:05 PM
dawtips's Avatar
dawtips
Default stuck heater switch
All of a sudden, my upper heater switch (the one that says Off -> Heat -> Defrost) got stuck and would only move to the left (towards Off). I pulled the heater controls out far enough to spray in some WD-40, but that didnt work. Also, reaching in behind the switch and moving it from back there allowed me to move it pretty close to the Heat marker. This car is my daily driver, so I kinda need heat and defrost. Help!
Old Feb 20, 2006 | 10:41 PM
1965MustangFastback's Avatar
1965MustangFastback
Default RE: stuck heater switch
Might be the cable? And not the lever, I'd look into the cable that goes from the lever to the heater box or maybe its the plenum. It could be stuck!
Old Feb 21, 2006 | 03:16 PM
dawtips's Avatar
dawtips
bah, Id rather not have to pull off the dash, I guess I'll check out that end of the cable, thanks
Old Feb 21, 2006 | 03:40 PM
Soaring's Avatar
Soaring
I ♥ Acer
Take out the ash tray and see if you can get to the two nuts that are holding the controls to the dash. If not, then the gauge pod will have to be removed. With the controls out of the dash, you can see if the cable is bent or broken or just rusty.
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
PaulH2
20
Jan 31, 2016 09:48 AM
guitarman376
Sep 30, 2015 05:54 PM
DreadPirateRoberts
Sep 26, 2015 02:11 PM
