Group Purchase on The Granada Swap Kit!!
Old 02-24-2006, 03:19 AM
degins
degins's Avatar
Default RE: Group Purchase on The Granada Swap Kit!!
ORIGINAL: popper
I'm interested too. I have a '65 Coupe. I would like to keep the exterior appearance fairly original looking but I can't use my 14" wheels with this swap. Any ideas?
Thanks,
Rich
If you want to keep the original look, find a set of wheels from any 5 lug 1975 and up Ford with 14" wheels. They will fit and they are 6" wide as opposed to the original 5" (5.5"?). They should be cheap and the original wheel covers should fit.
degins is offline
Old 02-24-2006, 09:06 AM
tylerdru
tylerdru's Avatar
alright we are making progress.
tylerdru is offline
Old 02-24-2006, 10:48 AM
Cusbuild
Cusbuild's Avatar
I would be interested in this, but how soon do we have to purchase for the group discount I am quite a ways from needing any of this yet.
Cusbuild is offline
Old 02-24-2006, 01:24 PM
degins
degins's Avatar
ORIGINAL: Cusbuild
Tylerdru is administering this group buy. I would assume that he is anxious to make the buy, so I believe that when he gets 5 solid buy commitments, the buy will be made. I'll give another week after that for others to take advantage of the group buy price.
degins is offline
Old 02-24-2006, 03:54 PM
Cusbuild
Cusbuild's Avatar
Yea I'm not going to be ready until summer (hopefully) more likely fall to get to this stage sounds like a great deal though. Look me up agian if there is a future buy.
Cusbuild is offline
Old 02-24-2006, 06:51 PM
Soaring
I ♥ Acer
Soaring's Avatar
ORIGINAL: degins
ORIGINAL: popper
Thanks,
Rich
So, are you saying that my 14" wheels from my original 65 which have a 4.5 inch Back Spacing won't work with this set-up? And, that I would need to invest more to upgrade to wider wheel spacing?
Soaring is offline
Old 02-24-2006, 09:54 PM
tylerdru
tylerdru's Avatar
Glen that is how it is with the granada swap. you need 15" wheels i thought.
tylerdru is offline
Old 02-25-2006, 01:58 AM
degins
degins's Avatar
Glen,
It's not backspacing that is the problem. The bearing boss of the Granada rotor has a larger diameter than the original. It wont pass through the center hole of the wheel. Some people advocate turning the boss down so it fits. I wouldn't. The calipers also tend to interfer with the inside of the original rims also. This is common with nearly all front disc brake swaps. Most require the use of OEM wheels designed for disc brake use, that is 1975 + ford 5 lug 14's, or aftermarket 15's.
degins is offline
Old 02-25-2006, 03:03 AM
Baker
Baker's Avatar
I'd be in for the kit for my 73!
Baker is offline
Old 02-25-2006, 01:40 PM
Soaring
I ♥ Acer
Soaring's Avatar
OK, thanks degins. I just wanted to clear that up.
Soaring is offline
Quick Reply: Group Purchase on The Granada Swap Kit!!
