One-eyed Mustang
Old Feb 24, 2006 | 05:33 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default One-eyed Mustang
Last night the better half and I took Ol' Yeller to a restaurant, and on the way home the passenger side head light went out. So, we went on home with one eye. This morning I went to the parts store and bought a new head light, but the only one they had that would fit a 65 was a Halogen lamp. Well, I took the old one out thinking it was the bulb, and found the connector to be corroded and the wires very brittle. That was the problem, and not the lamp. I tried to clean up the contacts, but one of them just broke in my hands because the plastic surrounding it was old and brittle. So, I just clipped the wires and soldered the wires directly to the halogen lamp. It works just fine that way, but I really need to replace the receptacle. Do any of you guys know where I can get a new one? Here are a few pics of the old one, and as you can see it is cruddy and chipped.
Old Feb 24, 2006 | 05:54 PM
65GTin GA's Avatar
65GTin GA
Default RE: One-eyed Mustang
If the recepticale at that headlight is bad, chances are the other one isn't far behind... I wouldn't just replace the receptical, I would get a while new wiring harness. Not all that expensive (the under dash one is!) and well worth the money. I replaced all the wiring harnesses in my car when I put it together and like I said, the tail light, engine feed, headlights and alternator feeds aren't priced like they are gold plated (just the underdash harness which is about $360)
After 40 plus years the things are brittle, cracked, hard as a rock and in some cases a potential fire hazard from shorts.
Old Feb 24, 2006 | 06:18 PM
Soaring's Avatar
Soaring
I ♥ Acer
I hear ya...that's one of my "round to it" projects.
Old Feb 24, 2006 | 07:44 PM
65GTin GA's Avatar
65GTin GA
I'd send you a "round Tuit", but they are extremely rare. Lots of square and rectangular ones floating around but the don't work like the round ones. If you do get a hold of a "Round Tuit" let me know I could use one too. They say that once you have a "Round Tuit" you can get eveything done that you said you would if you got a round tuit.
Old Feb 24, 2006 | 11:30 PM
19stang66's Avatar
19stang66
hahaha. You can buy that receptacle at any parts store im sure. I got mine from NAPA, they are cheap too. For the time being you might as well get a new replacement one, or I could give you my new one that I never used (i ended up buying a whole new harness), they just splice into the current wiring.
Old Feb 25, 2006 | 01:51 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
yeah i had to put one on my sabaru its a 99 common part to fail when old i think it was like $3.64!
Old Feb 25, 2006 | 11:48 AM
6mustang6's Avatar
6mustang6
Since we are talking about lights, I left work last night and cranked up the stang, and turned the lights on. I stepped out to talk to my friend. I looked at my tail lights and they were both off. so im like wtf? I opened my trunk and turned the driver side socket, and the light cut on as usual. The other side isn't working at all, no brake, or tail. I need to go check it.[:@]
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
Jan 6, 2016 07:03 PM
chain
Aug 17, 2015 08:52 AM
daytooday
Aug 11, 2015 09:22 AM
