are these some good heads for a mild 351w
Old Feb 26, 2006 | 09:09 PM
white69mach1's Avatar
white69mach1
Default are these some good heads for a mild 351w
are these some good heads for a mild 351w World Products Roush 200cc Cast Iron i know everybody is going to say go with aluminum heads but i dont want to spend the extra money so would these be a decent head and would they work on a stock short block if not what heads would
Old Feb 26, 2006 | 09:16 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: are these some good heads for a mild 351w
They are good heads, but for the 4-5 hundred dollars per head you will be spending for them, you could spend a few more bucks and get some aluminum heads. http://www.jegs.com/webapp/wcs/store...0187&langId=-1
Old Feb 26, 2006 | 09:42 PM
white69mach1
will there be anyproblems putting them on stock short block are will there be clearance problem
Old Feb 26, 2006 | 10:08 PM
Soaring's Avatar
Soaring
I ♥ Acer
Those heads have stock port locations, so there should be no problem.
Luke9222
Oct 22, 2015 11:55 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
cbird1177711
Sep 2, 2015 04:12 PM
kawiguy827
Sep 1, 2015 07:09 PM
