Early 1968 (Metuchen plant) engine bay colors
Hello,
I am getting ready to paint my engine bay area and wanted to verify the colors with somebody here who knows what color the various parts should be painted. I picked up some ford blue engine paint from Mustangs Unlimited for the engine.
I am planning on purchasing my other paint products from Eastwood as soon as I can figure out what colors I need.
1) Underhood semi-gloss black - fan - fan belt pully part and a/c hardware. I have also heard to use flat black.
2) Silver Cadmium - parts such as the hood latch, hood springs, and front fender bolts.
3) Was going to use the chassis black for the rear axel, brake drums and hardware and frame rails. The body and underside of my car has been primed and sealed.
I have attempted to find a listing of what part should be what color for a concourse correct car but have not had any luck locating this info. My goal is to get my car as close to concourse as possible but I will not enter that category due to some upgrades I intend to make with performance parts.
Can somebody here give me expert advice.
Brad
Roswell, GA
Brad
Roswell, GA
Semi. Cast iron parts were typically bare.
Latch, springs, hinges oiled phosphate (parkerized) Fender bolts silver cad.
Underbody was red or black primer, depending on when and where it was built. Drums were bare, except on cars with styled steel wheels, then the outer face only was chassis black.
Medium or light color cars had the pinchweld at the bottom of the rocker and quarter was blacked out with chassis black.
It is also possible to do stealth upgrades. Such things as lowering the upper control arms 1". I saw a 68 GT350 a couple years ago that was put together with 289HP exhaust manifolds, port-matched to the heads, and a C9OZ-C cam. Very stealth, unless you are very familiar with SB exhaust manifolds, and ran WAY better than stock.
ShaneB26154
35
03-04-2021 04:05 AM
