DIY Camber easy w/ torque thrust wheels
Camber measurements are repeatable and close to alignment shop print out.
Level car first.
Put car on turntable.
Measure camber directly using digital angle finder.
I know there are many other ways to measure camber.
Level car first.
I didnt have a fancy spancy digital angle finder. so I took my wheel off and returned the spindle to ride height and put my magnetic poor boy no digital angle finder against the spindles flat edge
Can measure camber on either side of disc brake rotor if have access.
Can also use a straight edge on rim and measure camber w/ angle finder or level. Straight edge does not need to pass wheel center line but needs to be vertical.
I don't know if it is good or bad but China is flooding us with cheepo fancy spancy tools that we couldn't all afford before.
Lethaldosage423
Oct 19, 2015 12:12 AM
