leaking
Old Jan 31, 2007 | 03:23 AM
undecided.steve's Avatar
undecided.steve
Default RE: leaking
ORIGINAL: lizlon17352
Hey, after tearing up my car to find this leak....I think I found it. I found that the back window is leaking on both far corners on the bottom. This water is leaking down those corners into the car and through the hole where the wire is in that plastic part where the covert top sits. Then that water leaks into the floor where the passenger sits.
That should not be happening though.
Sounds like the glue between the window and the vinyl might have seperated .
It is normal for a little water to leak down around the metal trim piece
and at the edges.
This is the water that should leak out the drains.
4cylinderplus2
Oct 9, 2020 07:45 PM
bradleyb
Nov 27, 2015 07:50 PM
jerrytubes
Oct 23, 2015 12:11 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
wraith777
Sep 28, 2015 10:49 AM
