03 leaking
Old Apr 12, 2008 | 10:59 AM
okie1's Avatar
okie1
Default 03 leaking
I have a 03 convertable that leaks behind the plastic trim on both a-pillars into the front floorboards everytime it rains. All of the weatherstrip looks good. Any help would be greatly appreciated, this thing is driving me nuts.
Old Apr 12, 2008 | 02:29 PM
undecided.steve's Avatar
undecided.steve
Default RE: 03 leaking
ORIGINAL: okie1
The drains under the car are plugged with debris....
Pull off the kick panel and look into the steel frame and you will see them.
Otherwise look under the car and you will see them.
They are not big, they are just slits about 2 inches long.
While you have the kick panels off, make sure all the holes are plugged with rubber grommets.
Mine had one missing.
BTW while you are at it, check the rear drain holes as well.
They are in front of the rear tires.
Water runs through the frame from front to back and should exit there, at least the water that hasn't exited from the front holes.
If you need any more information let me know.
Old Apr 12, 2008 | 09:49 PM
ryan1994mustang's Avatar
ryan1994mustang
i think he is talking about it is leaking where the front corners of the top meet the windsheild, at the top of the a-pillars. i have the same problem in my 94, but never really looked into how to fix it. if you figure out how, please post up some info. i think its a fairly common problem.
Old Apr 13, 2008 | 08:15 PM
undecided.steve
ORIGINAL: ryan1994mustang
Yes I believe you are correct.... My misread!
I would take the trim off and run a garden hose on spray (to simulate a typical rain) and watch.
It can't be that difficult now that he knows where the leak starts.
The hard part is when you find a puddle on the floor and have no clue where it came from!
Maybe the door is not closing tight enough and thus not compressing the weather stripping?
Top not latching tight enough?
Old Apr 16, 2008 | 10:40 AM
03GTVert's Avatar
03GTVert
You also might want to check the latches and make sure that they're adjusted properly and pulling the top down tightly enough.
Old May 21, 2008 | 02:21 PM
raysea390's Avatar
raysea390
My carpet in the rear passenger foot wells gets extremely wet when it rains, even when the car is parked. It's the fitted carpet that gets wet first, not the loose mats so the water is coming in from the bottom of the car somewhere. The doors seem to fit well and the rubber looks good so maybe it's those drain holesunder the kick panels? By kick panels you mean the plastic molding over the door sills you see when you open the doors?
Thanks!
Old Jun 24, 2008 | 11:45 PM
Rogeliod8's Avatar
Rogeliod8
This pisses me off!!! My Mustang leaks in the back and it just catches all the water in the back I can see where the water comes from but I dont want to make the leak bigger so thats why I have not messed with it. Ford Sucks for this!! Why can't they make anything that works like it should!!!
4cylinderplus2
Oct 9, 2020 07:45 PM
bradleyb
Nov 27, 2015 07:50 PM
jerrytubes
Oct 23, 2015 12:11 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
wraith777
Sep 28, 2015 10:49 AM
