Broken tension cable
Old Jun 26, 2008 | 03:52 PM
tidrow55's Avatar
tidrow55
Default Broken tension cable
Can you still use the power to if the tension cables are broke? Can you install the cables with the top on? Anyone know how to fill and purge the hydraulics on the top? If so could you please e-mail me at tidrow55@***.net
Thanks, Dwayne
Old Jul 4, 2008 | 07:35 AM
ewgoetz's Avatar
ewgoetz
Default RE: Broken tension cable
Should be a screw on the top of the pump that u unscrew and use as a fill hole. Then you press hte up button to riase the top and let it go all the way, than lower the top and top off that fill hole and you rinse and repreat till the top moves smoothly.
Thunderball
15
Nov 22, 2015 11:49 PM
kevsgt
Oct 9, 2015 10:12 PM
breaking
Oct 2, 2015 01:27 PM
MacSerio
Sep 27, 2015 01:05 PM
Sep 25, 2015 06:58 PM
