need help with 88 convertible
Old Jun 6, 2008 | 08:18 PM
Roger CT's Avatar
Roger CT
Default need help with 88 convertible
Got a 1988 mustang convertible. The back seat is saturated with oil that seems to have leaked for many years, thepump ( behind the back seat ) seems to have leaked and the two lift cylinders seem to be leaking too. What can be done to fix these leaks ?We plan to put new upolstry in this car and I want to fix these leaks.
Thanks alot
Old Jul 17, 2008 | 08:26 PM
nyfreakinrican7's Avatar
nyfreakinrican7
Default RE: need help with 88 convertible
You need to check the lines leading from the pump to the cylinders and see if it is leaking from there. If not that the cylinders and or the pump are leaking and will need replacing.
Old Jul 27, 2008 | 10:34 AM
Bobbo's Avatar
Bobbo
If the lift cylinders are leaking from the top where the rod comes out then they are no good & have to be replaced. Remove the triangle nut on the left side of the pump & clean it out. Fill with atf where the rubber plug is. You will have to fill the reservior a few times as you make the top go up & down.
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
lovesilver
Members Mustangs
May 9, 2019 09:18 PM
jerrytubes
Oct 23, 2015 12:11 PM
guitarman376
Sep 30, 2015 05:54 PM
