68 vert issue
Old Oct 8, 2008 | 04:51 PM
unit91's Avatar
unit91
Angry 68 vert issue
My 68 power top sits about 2 or so inches higher on the passenger side than on the driver side when down. I've checked the distance between the bows and it appears to be OK. I've adjusted side to side, but that didn't change anything. I adjusted the nut that adjusts the fit of the top to the door tops, and that didn't make any difference. Did I miss something? I can get the boot on, but the top framework on the passenger side is going to punch a hole in the boot if I'm not careful. Also the top vinyl is getting creased, and in one spot cut, by the frame when it folds down. Any suggestions?
Old Oct 10, 2008 | 01:48 PM
Blckstng93's Avatar
Blckstng93
Make sure nothing is bent, broken, or binding. Maybe check where the top mounts to the body and compare both sides. Thats all i can think of.
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Thunderball
15
Nov 22, 2015 11:49 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Bokeo
Oct 10, 2015 08:28 PM
