a few leaky questins
Old Nov 11, 2008 | 04:43 PM
moontang's Avatar
moontang
Default a few leaky questins
the ole vert has a few leaks and a few things i would like to ask about
1. it leaks near a spot where it folds near the windo seperations when it rains hard it drips on the speakers where is this comming from
2. it leaks around the rear glass but i see no obvious signs of tears or anything
3.the passenger quarter window doesnt quite roll all the way up it is just barely lower then the main window and thus causes a bit of wind noise what could be causing this?
Old Nov 13, 2008 | 07:06 AM
ryan1994mustang's Avatar
ryan1994mustang
around the back window it may just be beginning to separate like all convertibles do over time. and when you close the drivers door, does the window actually go into the weather stripping like it should, or does it just push on the outside of it? if its just pushing on the outside then its not getting a good seal all the way around. and im not sure about your window problem.
danltr450
Aug 23, 2007 07:29 PM
dstanger
Aug 20, 2007 10:08 PM
Martin123
Oct 10, 2005 11:07 AM
Martin123
Oct 8, 2005 09:41 PM
Shantymac
Feb 28, 2004 02:19 PM
