bleeding drop top motor cables
Old Oct 13, 2010 | 09:16 AM
mmaasika's Avatar
mmaasika
Default bleeding drop top motor cables
when replacing the motor how do you go about bleeding the lines?
Old Oct 13, 2010 | 10:51 AM
jwog666's Avatar
jwog666
i dont think that you have to, just run it up and down a few times and recheck fluid level.
Old Oct 13, 2010 | 02:53 PM
mmaasika's Avatar
mmaasika
thanks for the advice. I got the same suggestion from soneone else. he said because its transmission fluid the air breaks down inside, unlike brake fluid...or something like that.
anyway...all done. the top works! only thing is I have clamps holding in the rubber stoppers. How do I get those stoppers though the holes?
Old Oct 14, 2010 | 06:52 PM
scan1959's Avatar
scan1959
The rubber stoppers? There is only one I can think of. It is on the end of the hydraulic pump(conv. motor).
That can be reinstalled by taking a #2 Phillips screwdriver and slide it into the hole in the plug. After lining it up with the hole in the motor, slowly push it into the hole by pushing on the screwdriver.
Old Dec 22, 2010 | 08:01 PM
sinister99GT's Avatar
sinister99GT
i know its a old post , but to get the rubber mounts back in the holes , stick a dull ended rod into the hole of the rubber mount and use that to push it in the metal bracket. a screwdriver will work but you must be carefull not to poke it through the rubber .
Granatelli Sales
Jan 20, 2020 12:34 AM
musnicki
Sep 23, 2015 07:11 AM
spamedic
Sep 9, 2015 12:15 AM
zanemoseley
Sep 6, 2015 12:58 PM
tmdm
Sep 4, 2015 06:45 PM
