Fox Convertible Top Installation
Old Jun 13, 2013 | 02:15 PM
smac61's Avatar
smac61
Default Fox Convertible Top Installation
Installing a canvas top on a 1990 Fox.........At the front lower corner of the sail panel there is a "pocket" built in to the top material that hooks over the frame at that location. Inside the pocket, there is a piece of plastic cut in the same shape as the pocket. Is that plastic piece intended to be on the inside or the outside of the frame?
Old Jun 15, 2013 | 07:16 PM
numnutz's Avatar
numnutz
Default wear pad
The piece of plastic is intended to be used as a wear pad to keep the frame from rubbing a hole in the material. Memory's not as great as it used to be,so I can't say if it's inside or outside; but whichever way it protects the material. Luck.
Old Jun 19, 2013 | 12:09 PM
smac61's Avatar
smac61
Yeah, that was my conclusion. I currently have it installed to protect the outside, but I am planning to make a minor adjustment in that area and want to get the question resolved. All in all, pretty easy job with some preparation and patience. Used Stayfast canvas and it turned out great. Thanks for the input Num!
Old Jun 19, 2013 | 07:53 PM
scan1959's Avatar
scan1959
smac,
I always put the corner of the pillar into the pocket so that it would stay in place. This way, the plastic is on the inside of the metal pillar and the outside of the top stays on the outside of the metal pillar.
Luck.
Old Jun 20, 2013 | 10:55 AM
smac61's Avatar
smac61
Originally Posted by scan1959
smac,
Luck.
Thanks Scan!
Roger Mabry
Jun 15, 2016 08:27 AM
importsmasher
Oct 9, 2015 04:42 PM
Calizic
Aug 28, 2015 01:46 PM
MXBT187
Aug 20, 2015 02:36 AM
Mustang Sally72
Aug 11, 2015 07:54 AM
