Well Liner
Old Mar 24, 2015 | 10:29 AM
RGreene02's Avatar
RGreene02
Default Well Liner
Just joined the forum a few minutes ago because I'm looking for advice on how to remove the top well liner. I have a 2002 V6 and had a new top installed last week. It sounds like the installer left a tool behind as I can hear it rolling around. I've seen that the replacement process is "simple" and should only take about an hour, but I haven't found any instructions on how to remove the liner.
Any Help?
Old Mar 24, 2015 | 10:44 PM
cruisin5268d's Avatar
cruisin5268d
I can't help with your issue, but welcome to the forum. You should get some solid responses soon!
Old Mar 25, 2015 | 06:28 PM
Special20's Avatar
Special20
If you are talking about the liner directly behind the rear seat, it just pops off of the black nuts right below the rear window. It is possible that something else is loose and the rear seat must be removed to investigate. Hope this helps
jwog666
Dec 27, 2021 08:09 PM
MonsterBilly
Sep 19, 2015 08:50 PM
Sparks_88
Sep 8, 2015 01:06 PM
hpaddict
May 25, 2006 11:34 PM
03redGT
19
Mar 9, 2006 11:33 PM
