Tail lights hazy and dull
Old Apr 1, 2006 | 01:33 PM
WhiteHorse94's Avatar
WhiteHorse94
Default Tail lights hazy and dull
I have a 94 convertable, the tail light lenses have been hazy and dull for quite some time.
Was wondering if anyone knew of something that could help.
Old Apr 2, 2006 | 01:34 AM
Jim D.'s Avatar
Jim D.
Default RE: Tail lights hazy and dull
Mothers PowerBall Mini with Plastic Polish -- if they're really hazy, use the PowerMetal polish first to do a good cut.
Now you might want to carefully mask the surrounding painted areas with light painter's tape, but do a test area first to make sure the 11-year-old paint won't lift. If you're careful, you might be able to get by without masking, but expect to keep after a little bit of sling.
It's excellent for headlights, too.
Old Apr 2, 2006 | 09:15 PM
jpc's Avatar
jpc
Here is a link to the Honda S2k sight, ( wife has a s2000) anyways this guy used Plastic 210 I'm pretty sure you can buy the stuff at your local marine shop, i guess alot of boat people use it.. he also used a buffing wheel but ended up with good results.. also look around on the finish section while your there, they have a bunch of good tips......http://www.s2ki.com/forums/index.php?showtopic=296109
Old Apr 3, 2006 | 08:55 PM
WhiteHorse94
Ended up using Mothers Plastic Polish....here are my results, before and after
[IMG]local://upfiles/32977/33FD55B4ED6B4E0E82830A840C244C5C.jpg[/IMG]
[IMG]local://upfiles/32977/199885C330A9420287E571BE13809019.jpg[/IMG]
Old Apr 4, 2006 | 03:34 AM
jpc's Avatar
jpc
Those came out really good, did you use the power ball with the plastic polish like Jim D described or did you do it by hand
Old Apr 4, 2006 | 04:34 AM
adahlenburg's Avatar
adahlenburg
Wow the color of the white even shined up.
Umm did you just crop a photo of a brand new one???
Old Apr 4, 2006 | 09:04 PM
WhiteHorse94
I bought the powerball but ended up doing it all by hand after some testing and seeing good results......
And NO...the after picture is not a new tail light or a different car, just the right hand side as opposed to
the before picture which is obviously the left hand side!! (i used the right side for the after because the light
was better for a decent picture, which is probably why it looks whiter)
This is the left side after.
[IMG]local://upfiles/32977/253308D3D15F4C9196EA8C1DDE9A8F10.jpg[/IMG]
jwog666
Dec 27, 2021 08:09 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Explosive
Oct 2, 2015 07:45 AM
folivier
Tennessee Regional Chapter
Oct 2, 2015 05:32 AM
