Need help Painting CAR....
im paintin my ranger.. yellow.. but its my first time.. its a beater car just tryn to learn how to paint good.. what kinda sand paper should i use to sand the truck?.. and so on..
Follow my sticky at the top. It will be a while till I finish it but I plan on putting as much detail in th earticle as possible. I will be covering sanding and body work in the next few days.
I work at my buddy's body shop during the summer and they always use 220 grit to sand the filler. Once they apply the primer, they wet sand it with 400 grit "wetodry" sand paper. After that, they prime it again and wet sand it again. During the wet sanding process, they like to use a little bit of comet cleaner to help "cut" the surface and reduce sanding time. The main thing is to be patient and I can't stress that enough.
ORIGINAL: catch_15
Oct 1, 2015 09:29 AM
mungodrums
Sep 28, 2015 10:54 PM
