Optimum No Rinse Wash
Old Nov 16, 2006 | 11:13 PM
Juztang's Avatar
Juztang
Default RE: Optimum No Rinse Wash
Jeff I'm glad that you are happy with everything. You should post some pictures of your stang. I think your dad will really like the products. They are very simple to use and produce awesome results.
Old Nov 17, 2006 | 10:53 AM
IA_Chiefs_fan's Avatar
IA_Chiefs_fan
I just ordered the Optimum Car Wax Spray, Poorboy's Leather Stuff & the Optimum No Rinse from Juztang. Thanks for the super-fast delivery. I hope I can use them this weekend. I don't have a garage or anything so I'll have to do it outside. What is the minimum temperature I should wait for? Also, since this is the first nice car I've ever had to care for, I'm unfamiliar with some of the lingo. What is a clay bar lube. The No Rinse tells you how to make it but not how to use it. (I'm sure everyone else already knows what it is) Also, how do you use it as a quick detailer? Lastly, I live in Iowa where there is always a lot of salt on the roads. Will this Spray wax protect against the salt etc. as well as a regular wax? Thanks
Old Nov 17, 2006 | 11:09 AM
tim1200's Avatar
tim1200
What is a clay bar lube? The No Rinse tells you how to make it but not how to use it.
The clay bar lube is what you use when you clay bar the car, you spray the lube on the car and the clay bar will slide over the area sprayed. If you don't know what clay bar is just do a quick search you'll get all the information you need.
I think the as long as the wash isn't freezing to the car you can wash the car when you want, for me if I am shivering its to cold to wash.
Your wax will protect the car you just need to make sure get the salt off the car as quickly as possible, salt sitting on the car for any length of time is bad.
Old Nov 17, 2006 | 05:00 PM
Juztang's Avatar
Juztang
Everything Tim said is correct. I actually use the No Rinse no matter how cold it is but I pull the car into the garage to do it. What I do is get a bucket and fill it with about 2 gallons of warm water and another bucket with warm water as your rinse water. I have heard of people on the detail forums using mittens and putting rubber gloves over them in the winter. This way your hands won't get cold. Also you can use this wax in any temperature. There have been many people on the Autopia.com detail forums use the Optimum Spray Wax in the winter and temperatures close to 0. I can't imagine doing this but I have read about people using it and working!
A claybar will take all the contaminants out of the paint and make it silky smooth. A way to tell if your paint needs clayed is after you wash it... take a ziplock baggy or similar and put your hand in it and rub it over the paint. If the paint doesn't feel smooth and it feels kinda rough it needs clayed.
You can use the quick detailer for when your vehicles is barely dirty or dusty to get the car clean again.
djbigskrilla
Sep 20, 2022 01:04 AM
jerrytubes
Oct 23, 2015 12:11 PM
GLOCKer
Sep 28, 2015 07:36 AM
Mr. D
Sep 17, 2015 08:17 AM
Bryan@Autogeek
Aug 5, 2015 12:33 PM
