Removing emblems from painted surface
Old Jan 18, 2005 | 11:10 AM
AllVenom's Avatar
AllVenom
Default Removing emblems from painted surface
I'm looking for suggestions on how to remove emblems without damaging the paint job. Thanks!
Old Jan 18, 2005 | 11:27 AM
brando5.0's Avatar
brando5.0
Default RE: Removing emblems from painted surface
I would try to use a heat gun to soften the adhesive, and then peal off the emblem. Then, I would use a product called Goof Off ,or, (im sure someone is going to go against this because they dont know any better) use laquer thinner to remove the adhesive. Do NOT use a metal razor blade. You can find some plastic blades, and they usually work pretty good.
Old Jan 18, 2005 | 01:32 PM
code3GT's Avatar
code3GT
Mustang Nazi
Use a hair dryer to heat the adhesive then use a piece of dental floss and slide behind the emblem, work the floss down through the adhesive. Once the emblem is off, use "goof off" to remove the remainder of adhesive and finish off with 70% rubbing alcohol to remove the goof off residue. Finish off with a good coat of wax. There you go.
Old Jan 18, 2005 | 01:34 PM
AllVenom's Avatar
AllVenom
Thanks guys, I didn't even think of the hair dryer![sm=goodidea.gif]
Old Jan 18, 2005 | 05:29 PM
MikeHawke's Avatar
MikeHawke
Retired MF Moderator
ORIGINAL: AllVenom
are you just swapping emblems or taking them right off?
the fender ones have a pin that locates them, so there's a hole in the body but the trunk ones are flat...they can come right off without a mark.
the dental floss and goof off is great WITH the hairdryer.
Old Jan 18, 2005 | 06:01 PM
Phillyblunt474's Avatar
Phillyblunt474
good replacement for "goof off" is "goo gone" since you may nogt be able to find the goof off
Old Jan 19, 2005 | 02:13 AM
Jimmz's Avatar
Jimmz
You can also use dental floss. Just make sure its the soft kind and then just rub back and forth. A couple of my friends did that and it didnt hurt the paint at all. Im not sure if a blow drier would work, so if it doesnt I would try the floss.
The emblems on the fenders dont have any pin holes you just stick them on. The only emblem that has the pin holes is the ford emblem in the back of the car.
Old Jan 21, 2005 | 06:43 PM
AEman14mh's Avatar
AEman14mh
not very hard to do. just use fishing line and run it behind the decal to pull it off then any kind of goo-b-gone product will take car of the rest. i guess dental floss might work too but i have always used fishing line because its pretty strong
jwog666
Dec 27, 2021 08:09 PM
Dathan
Oct 5, 2015 05:52 AM
Oct 1, 2015 09:29 AM
mungodrums
Sep 28, 2015 10:54 PM
GLOCKer
Sep 28, 2015 07:36 AM
