HELP!! Can't Remove Spots From Paint
Old Oct 1, 2007 | 09:22 AM
PiggySmallz's Avatar
PiggySmallz
Default RE: HELP!! Can't Remove Spots From Paint
yes the car is under warranty, i've only had it for a month. But it does run reliably and sounds mean unfortunately the car looks like a fairy with those little spots on it now lol. Ill try to attack more of it when I get home from work before I head to class. Thanks for the help
EDIT: Should I try a stronger cutting pad?
Old Oct 1, 2007 | 11:38 AM
04MustangGT's Avatar
04MustangGT
NEVER MIND THE CLAY BAR!!! Get yourself the 3M compound. There are a few of them, but the one I am talking about is about $75.00. It will work and you will have to use a lot of muscle and
Remember take your time with it. Slow and steady wins the race
Old Oct 1, 2007 | 11:58 AM
Dan04COBRA's Avatar
Dan04COBRA
Why would he need 3m compound? He has Poorboys SSR2.5
Old Oct 1, 2007 | 06:54 PM
ZAXJAX's Avatar
ZAXJAX
Menzerna Intensive Polish will take that right off. Autogeek has it on sale!
Old Oct 1, 2007 | 10:16 PM
PiggySmallz
is that any more abrassive than poor boys ssr2.5? this is definitely paint. My friend's dad is the sergeant of the verazanno bridge so im going to file a report and bring it to a detailer and let them pay the bill. If they are not willing to do it then I am willing to try ANYTHING
Old Oct 1, 2007 | 10:26 PM
Juztang's Avatar
Juztang
Poorboys SSR3 is the next and most abrassive in the Poorboys lineup. Optimum Compound is a little stronger than the SSR2.5 and their Hyper Compound is the most aggressive.
It sounds like you might need a more aggressive claybar. Find a local auto body supply store and try to find a more aggressive bar. This will most likely leave some marring behind. Then you can use the polishes you have to remove the marring.
Old Oct 1, 2007 | 10:32 PM
Dan04COBRA's Avatar
Dan04COBRA
Justin, could you just lighten the amount of lube (minimal amount of lube so it doesn't stick or grab) and rub a bit harder?
I used a light amount of pressure with my crazy glue incedent, it helped remove a majority of the high point in the spot, most of the time it took it right off - but the crazy glue etched the clear a fair amount until I took the buffer to it. Was I playing with fire or was it a cheap solution?
Old Oct 1, 2007 | 10:36 PM
Juztang's Avatar
Juztang
You want to use plenty of lube when you are claying, the claybar shouldn't catch or grab at all. I try not to apply any pressure at all and just let the claybar glide over the surface until it finally removes the contaminants.
I think since you start working on the glue right after it happened helped out a lot. If it would have completely cured it would have been so much harder to get off.
jwog666
Dec 27, 2021 08:09 PM
Dathan
Oct 5, 2015 05:52 AM
Oct 1, 2015 09:29 AM
GLOCKer
Sep 28, 2015 07:36 AM
popsotto
Sep 28, 2015 06:58 AM
