Question about claybar
Old Nov 11, 2007 | 06:30 PM
Adam03GT's Avatar
Adam03GT
Default Question about claybar
I bought the mothers claybar kit and tried to use it in the middle of june.... Bad idea. I could have sworn i was tearing the crap out of my paint.
So after maybe 3 minutes i put it straight into a plastic baggy and i just now found it.....
Is it safe to try and use it again?
Old Nov 11, 2007 | 09:40 PM
Cooter's Avatar
Cooter
Default RE: Question about claybar
Does it still feel the same as it did when you bought it? Did you use enough lubricant when you were claying your car? The clay will grab at first when you start on a section and then get easier and easier and then it glide back n forth across the paint. Cut the clay into sections, that way if you drop it, you won't have to throw the whole thing away.
Old Nov 11, 2007 | 11:36 PM
TPony's Avatar
TPony
It should be safe as long as it's clean (no particles) or it will screw your stang up. Take the clay in your hand and knead it for a bit, ensure you have plenty of lub to it will glide on the paint. There's no such a thing as too much lub when using the bar.
Old Nov 12, 2007 | 02:03 AM
v6kid07's Avatar
v6kid07
Another main thing is when you stored it did u spray it with clay lube to keep it wet so it doesnt dry out? Sometimes when claying your paint it might even take a minute or 2 on one area. Took me that long on a customer's car at the rear bumper below the license plate.
Old Nov 12, 2007 | 12:32 PM
SVTBill's Avatar
SVTBill
ORIGINAL: TPony
+1 on the lube, i used the mother's clay kit before and the bottle of clay lube they included was not enough for me to do my stang with, i mixed up some more and did the rest (had about 1/8 left)
to mix up clay lube all you need to do is take a couple of drops of car wash soap and dilute with water, you can use the same bottle your original clay lube came in.
this solution can double as a quick detailer too!
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
