brush marks
Old Feb 2, 2008 | 06:06 PM
MelloYello's Avatar
MelloYello
Default RE: brush marks
Ok let me give you some advise first before you do this!!!! People think its easy to just take D/A or a polisher to a car but its not that simple and if your not careful youll burn through...
If you can take your fingernail over the scratches and you feel the ridge more than likely the scrathes are too deep.... if they cut just through the clear your ok... you can actually take some 400grit to the clear with some water take the majority of the scratch out... Dont push hard.
3M makes good compounds to use!!!! Use a dark compound with low grit with a polisher and a white pad... buff at medium speed and dont stay in one spot.. if the panel becomes warm to touch STOP!!!! 3M also makes this other stuff that is the MUST HAVE for especially black cars!!! Its a swirl remover, the compound is blue!!!! use this last!!! then wipe away with the cloth..... You want to do this in 3 stages!!! I just prefer 3M product
You should be able to get them all out this way if they arent bad! Dont do it often though!!!!!
Old Feb 3, 2008 | 09:47 AM
blkthndr03's Avatar
blkthndr03
mello the marks are just in the clear there not that deep i have one deep scratch on the door from where my dog jumped on my car but i no that a polisher wont take that out
Old Feb 4, 2008 | 11:33 AM
janine's Avatar
janine
I use a very light compound and mother's hard wax. Check out the results....
[IMG]local://upfiles/10629/77CFEA3422C247A281E3FAFD0FBEDB6E.jpg[/IMG]
[IMG]local://upfiles/10629/E388D6B9687F4C99B11945BBDF4A7F60.jpg[/IMG]
[IMG]local://upfiles/10629/6F8F00319C9C411888EB75A00D7A01C0.jpg[/IMG]
[IMG]local://upfiles/10629/32531D0DC6B84FEA8E5C0A4446881390.jpg[/IMG]
Old Feb 4, 2008 | 03:31 PM
blkthndr03's Avatar
blkthndr03
hey looks good man did u use a pc or by hand
Old Feb 4, 2008 | 08:17 PM
janine's Avatar
janine
By hand.
If you use a machine on black paint, you will seecircular rotations in the reflection. Machines are stronger than elbow grease (my elbow grease at least, I am a girl)as theytend to dig in and leave their marks.
I recently used a light rubbing compound by Mothers and then Mothers hardpast wax. It is yellow in a big round can. Cost about$16.
It will take time to do it right. You can't rush it. And it has to be done under shade.
Old Feb 4, 2008 | 09:22 PM
blkthndr03's Avatar
blkthndr03
what kind of material do u use to polish it in with microfiber????? also what was the grade of polish meaning heavy medium light etc.
tmdm
May 2, 2021 02:49 PM
baddog671
Jul 26, 2016 01:20 PM
wishinsky
Sep 21, 2015 09:48 AM
Aug 12, 2015 05:39 PM
