How do I clean MF towels?
Old Jul 13, 2008 | 08:23 PM
Cooter's Avatar
Cooter
Default RE: How do I clean MF towels?
I wash my wheels (chrome) all the time with microfiber towels ( soaked in car wash/water) and have not experieced any sand paper like scratches on them.
I just dont see how a wet m/f even feels like sand paper OR would even cause scratching like that of sand paper.
People use M/F towels washing their cars with ONR or car wash. Seems like it would be worse on clear coat than it would be on aluminum.
[align=left] [/align]
Old Jul 13, 2008 | 09:41 PM
SALEEN429's Avatar
SALEEN429
they won't scratch chrome but they will scratch aluminum.
if you don't believe it try it. just be prepared to polish out the scratches in your wheel when you get done.
I did not believe it at first until the guy showed me how bad wet MF will scratch a wheel.
Old Jul 13, 2008 | 09:55 PM
Cooter's Avatar
Cooter
Was the wheel dirty or clean??
I dont believe its the m/f (unless its low quality and there are many different brands out there and not everyone uses the same)
Since when did water have abrasives in it?? Hmmmm
Old Jul 13, 2008 | 10:09 PM
SVTBill's Avatar
SVTBill
p {margin:0px;}just because your friend scratched his wheels, that time with a MF does not mean every single aluminum wheel will get scratched when being rubbed by a damp MF. aluminum, in comparason to clearcoat is very hard. i dry my aluminum wheels all the time with no marring at all. the only way a damp MF can scratch an aluminum wheel is if the wheel is covered in brake dust and/or dirt, and the person rubsthe dirt/dust inwith excessive pressure.
Old Jul 13, 2008 | 10:53 PM
SALEEN429's Avatar
SALEEN429
Hot Flash - Products
Check out the bottom of the page.
Try it and you will see it leaves very small scratches in the aluminum when you rub a microfiber towel on it with some pressure.
Old Jul 13, 2008 | 10:58 PM
SVTBill's Avatar
SVTBill
of course you're going to scratch aluminum wheels if you rub chrome polish on them, doesn't matter if you're using an MF towel, paper towel, cotton or sand paper. the arguement at had was a "wet" MF towel, not a MF towel soaked in chrome polish.
Old Jul 13, 2008 | 11:24 PM
SALEEN429's Avatar
SALEEN429
It is not about polishing aluminum with chrome polish. It is about scratching aluminum with microfiber. It just says never polish billet with MF. I never said it would scratch anything other than aluminum nor did I say I just knew a friend that did it. I have done it and know for a fact it will scratch aluminum. I never said all aluminum, harder aluminum it doesn't scratch but soft metals it will.
Old Jul 13, 2008 | 11:27 PM
SALEEN429's Avatar
SALEEN429
I am not trying to start an argument but instead of thinking its a bunch of BS why dont you take a billet wheel and rub on it with a MF towel and tell me what you see.
Old Jul 13, 2008 | 11:41 PM
SVTBill's Avatar
SVTBill
ORIGINAL: SALEEN429
are you trying to say a MF damp with water will scratch aclean polished alumnium wheel if rubbed on it? because that is not correct. i've rubbed MFs across clean polished aluminum wheels before, and it did not scratch. as a matter of fact it was getting paid to do it, too, because i detail on the weekends.
a clean, damp MF rubbed on a clean aluminum wheel will simply,not scratch it. there has to be some sort of dust/dirt inbwetween the MF and the wheel. clean, well maintaned microfiber towels are safe for clear coat and almost every automotive surface. i recommend a quick detailer between the paint and the surface to prevent scratching. scratching from dirt, not the towel its'self.
Old Jul 14, 2008 | 03:00 PM
sowaxeman's Avatar
sowaxeman
Retired Moderator
We are talking apples to oranges here folks. Rubbing a wet mf on uncoated, polished aluminum is much different then rubbing it on a clearcoated paint job. But I also believe if a damp mf is causing fine polishing scratches on polished aluminum, then there is either dirt/dust in the MF or on the wheel itself. Chrome Polish has chemicals in it that are not meant for aluminum, thus why would you try to prove this theory by using it on aluminum? And aluminum polish has abbrasives in it that are not meant for chrome.
This sounds like a whole different subject that I am always happy to voice my opinion on....before you use polishes on your wheels, know what the heck you have because there is a whole ton of difference between chrome and polished aluminum.
