I have a 1996 mustang GT with clouded headlights. Is there a way or product out there to make them transparent again. Or should they be replaced thank you
3M makes a product that is just for hazed headlights. I have heard good things about it but it will probably require a little effort. Might be a good time to upgrade your headlights
all you have to do is wet sand them w/ 1500 grit sand paper. then using 1500 grit compound use a high speed buffer. after they clear up put a good wax on them. the whole thing takes about 15 to 20 minutes. just tape off every thing surrounding the lights. and pop the hood.
