Yellowed headlights
Old Aug 30, 2008 | 01:55 PM
00stang_man's Avatar
00stang_man
Default Yellowed headlights
I just bought a 2000 ford mustang thats in perfect shape with low miles, but the headlight lenses have that nasty yellow haze on them. Anyone know of a good method to get rid of it without damaging the plastic?
Old Aug 31, 2008 | 12:27 AM
SVTBill's Avatar
SVTBill
https://mustangforums.com/forum/detailing/402703-headlight-repair.html
do you have any pictures of the lights? you may not need a ton of wet sanding and polishing. if you're lucky you might be able to get away with a mild polish.
Old Sep 3, 2008 | 11:00 AM
00stang_man
thanks, i've been away so I will give it a go soon. they are really bad so i'll try my best.
Old Sep 3, 2008 | 06:05 PM
hookedonkronik's Avatar
hookedonkronik
Buy Meguires PlasticX.
I just rubbed this on and off with a clean cloth. I honoustly couldn't believe the difference from one headlight to the other when I finished 1 of them.
Old Sep 6, 2008 | 10:12 PM
stang_krazy's Avatar
stang_krazy
And if you have a pc with speed dial on 5 and a foam cutting pad then follow up with a polishing pad also with the plastX on speed dial on 3 the outcome is fantastic!
Old Sep 6, 2008 | 11:53 PM
Jayz's Avatar
Jayz
rubbing compound works great.
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
StalkerGT
Nov 28, 2015 03:09 PM
Gene K
Oct 21, 2015 11:37 PM
Drastang
Sep 29, 2015 03:31 PM
cbird1177711
Sep 3, 2015 08:43 PM
