Water spots....
Old Mar 3, 2010 | 04:42 AM
Nestang's Avatar
Nestang
Exclamation Water spots....
Whats the best method and things to use to remove hard hard water spots from the glass and the paint? Ive tried using clay bar but never could seem to get them all. Thanks
Old Mar 3, 2010 | 05:23 AM
isjoining's Avatar
isjoining
polish
Old Mar 3, 2010 | 01:32 PM
Juztang's Avatar
Juztang
Polish as mentioned about will remove most waterspots. Another option is vinegar and water diluted 50:50, this helps break up the mineral deposits.
Some waterspots that are really bad can etch into the paint and the only way to remove these are to wetsand. You only want to wetsand as your last resort. Tryout the polishing or vinegar method first.
Old Mar 7, 2010 | 11:24 PM
Nestang's Avatar
Nestang
Originally Posted by isjoining
polish
haha ya guess I should have been more specific, what Brands have you had the best results with. I usually use Mothers because theres not much to choose from unless I order online. But I have some pretty hard water spots, on both the paint and glass. Ive tried some polishes and stuff on the glass but nothing seems to cut it.
Old Mar 8, 2010 | 11:56 AM
Juztang's Avatar
Juztang
You always want to start with the least aggressive method first and then work your way up. I would try a polish like Meguiars 205 first and if that doesn't work bump up to the Megs M105. Both are excellent products.
Old Mar 8, 2010 | 03:00 PM
Stealth's Avatar
Stealth
I've got some bad water spots on my rear window. Is there anything special to consider when polishing glass with a porter cable? Is it pretty much the same as doing the paint?
Old Mar 8, 2010 | 03:08 PM
Juztang's Avatar
Juztang
I always polish glass the same way I do on paint, sometimes it takes longer to polish out imperfections on glass though.
Old Mar 8, 2010 | 10:20 PM
01GTturbo's Avatar
01GTturbo
Def polish would take care of it. Are you talking like permanent or just from drying after a wash and come off easily with a lil elbow grease and cleaner?
Old Mar 11, 2010 | 03:57 PM
GT John's Avatar
GT John
Mothers Clay Bar...........available at Auto Zone.
Old Mar 16, 2010 | 04:50 AM
Nestang's Avatar
Nestang
I've used a clay bar, I think I just need to sit down with about 2-4 of the clay bar kits lol. To 01GTturbo they are pretty permanent water spots, Although I think if I went through enough clay bars it would work pretty well. I've tried turtle waxs liquid clay bar and It didnt seem to work as well as the mothers. I'm just going to have to get some heavier polish and clay bars and spend some days detailing and see how it goes. Any good recomondations for a polish for the glass? I've tried some kind of rain-x polish but I think it may have just been no good due to heat/freezing and just old.
jwog666
Dec 27, 2021 08:09 PM
Thunderball
15
Nov 22, 2015 11:49 PM
jerrytubes
Oct 23, 2015 12:11 PM
b8checker
Oct 8, 2015 12:55 PM
