Yellow Interior
Old Aug 27, 2005 | 03:04 PM
Zincpony's Avatar
Zincpony
Default Yellow Interior
I've decided to paint my interior trim kit yellow but i dont know where I should start or what i should do. help please
Old Aug 27, 2005 | 03:46 PM
Zincpony's Avatar
Zincpony
Default RE: Yellow Interior
This is what im planning
Spread everything on an old Sheet.
Windex with Amonia everything.
Coat of Primer
1 or 2 light Spray coats of yellow
1 full coat of yellow
then Clear Coat.
Old Aug 27, 2005 | 05:20 PM
AtlanticBlue99's Avatar
AtlanticBlue99
I ♥ Acer
take out pieces. put on cardboard (no fibers like a sheet) and use ALCOHOL to wipe pieces down and remove oils/waxes. now you can just paint 4-5 light coats of paint for a base and then 3-4 coats of clear for a shine
*important* give ample flash periods and let dry 1 hour before trying to reinstall anything, then leave windows down so car doesnt fume up
Old Aug 27, 2005 | 06:32 PM
Zincpony's Avatar
Zincpony
cool thanks for the info much appreciated
Old Aug 28, 2005 | 01:50 AM
redass02gt's Avatar
redass02gt
EXTREME Moderation
you should sand before spraying. search on other stang sites, you will find a how - to somewhere, I've seen them before.
Old Aug 28, 2005 | 01:55 PM
AtlanticBlue99
I ♥ Acer
i didnt sand my trim pieces and paint hasnt chipped off or anything in over 6 months. if you sand you will lose the texture of the piece painting. if you want a smooth high gloss finish, sand; if you want a factory colored gloss finish, dont sand
Old Aug 31, 2005 | 07:32 AM
YinYangStang's Avatar
YinYangStang
my only advice would be if it is at all possible, hang the pieces and spray them so you can hold the can horizontal the way it's meant to be used. Sometimes it can be a pain to get an even coat when you're painting on the floor.
You only really need to sand if there is already paint on there. Any mistakes can be cleaned when it dries with Goof-Off, but use it very lightly, as it'll take the paint back off, but also the plastic. Good luck.
Old Sep 3, 2005 | 02:13 PM
Caldwell's Avatar
Caldwell
don't forget the pics when you're done :P
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
b8checker
Oct 8, 2015 12:55 PM
jrrhd73must
Oct 2, 2015 09:17 PM
b8checker
Sep 30, 2015 07:11 AM
treesloth
Sep 28, 2015 07:03 AM
