Questions on paint
Old Jan 4, 2006 | 08:10 PM
Shifty Powers's Avatar
Shifty Powers
Default Questions on paint
well i need to repaint the rear bumper on my 98 v6... how hard is it to strip down, prime and prep, and then get it painted? also we are doing this for my freinds 96 firebird...
anyone have any advise on what to do, conditions, what to use, how to do things? anythiing i should be concerned about?
all possible information would be much appreciated....
thank you
pat
Old Jan 8, 2006 | 01:40 AM
shuribob's Avatar
shuribob
Default RE: Questions on paint
I have found over my many years that good paint and body work is best left to the experts. If inexperienced people try to do the work it will show. Save your money up and then get it done right. Since I don't have to drive your car or be seen in it I guess its your choice in the end. Lots of information on the internet by googling so it shouldn't be too hard to find step by step instructions. Good Luck....
Old Jan 16, 2006 | 01:02 AM
Sickspackstang's Avatar
Sickspackstang
there is nothing wrong with doing the prep work yourself. prep work is by far easier and cheaper than just taking it to a paint shop. what you always want to do is start with some pretty rough sandpaper and sand the whole thing down nicely until the paint you have looks cloudy, the wash it off to see if you missed ANYTHING. start the process over with a finer grit paper, then finer, finer and finer. pick up some duplicolor prep wipes they are like degreaser towels. wipe the bumper down with this, let it dry and now you are ready to primer, use some sandable primer from duplicolor, the color doesnt really make a difference just use ur head. go back and forth in a sweeping motion and apply a very light coat, then do it again in 10 minutes with a little heavier of a coat, then 10 more minutes and give it a nice coat, you can give it another in 10 minutes if you want but that should be enough. then you want to let it dry overnight. sand it with like p800 then p1000. use another prep wipe on the surface and now its ready for paint.
Old Jan 16, 2006 | 01:03 AM
Sickspackstang
u can strip the paint if you want but it is not needed
tmdm
May 2, 2021 02:49 PM
guitarman376
Oct 11, 2015 01:47 AM
Ipaman
Sep 22, 2015 07:01 AM
mustangchef
Sep 4, 2015 08:08 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
