Surface Scratch Removal
Old Feb 6, 2006 | 11:25 AM
sowaxeman's Avatar
sowaxeman
Retired Moderator
Default Surface Scratch Removal
Hey gang - talked to the Maguires rep this weekend at the World Of Wheels. Got his thoughts, now I'd like some mf'ers opinions based on your experience.
Got a few minor surface scratches in the clear on my trunk lid. Not very noticeable unless you look in the reflection of light just right. I know they are there so I'm bothered by it Anyone have any likes or dislikes with the Scratch X product applied by hand, or the Step 1 Paint Cleaner product in the red bottle (step 2 is the polish, and step 3 is the wax) when applied with an orbital??
Old Feb 10, 2006 | 12:41 PM
sowaxeman's Avatar
sowaxeman
Retired Moderator
Default RE: Surface Scratch Removal
Nobody's used either of these products? I'm probably going to go orbital with the 3 step red bottles (Cleaner, Polish, Wax) but was hoping to hear some first hand opinions [&:]
Old Feb 10, 2006 | 06:09 PM
StevesGT's Avatar
StevesGT
I live and die by Scratch X,...if its a fairly light scratch. Unfortunately it cant work miracles. But with some elbow grease, it does a good job. Just remember to throw a new app of wax once you have worked the scratch out the best you can. And I only have done it with an aplicator pad, not a power buffer.
Old Feb 12, 2006 | 10:43 AM
jlmust's Avatar
jlmust
HI! I'm new on this site.but my 25 year background in automotivive refinishing may help some.for very minor scatches[not below the clear coat],try wet sandin the scratch area with 3m 2500-3000 sand paper with 3m wet sanding sponge[SOFT ON ONE SIDE/HARD ON THE OTHER SIDE][make sure and sand flat with med pressure]then power buff with a 3m compound sponge pad with 3m buffiing compound[again flat and keep moving]till the sanding marks are gone,then power buff with a 3m glaze sponge pad and 3m glaze[in white or dark grey depending on your paint color]buff to a show room shine,when you think you have it shinning the way you like it,wax with your favorite wax.This may cost you $100 in product but will last for timeand time again,its than refinishing,take your time,be gentle and have fun,its worth it.[ALL PRODUCTS WORK GREAT,ITS JUST I HAVE BEEN USING 3M FOR YEARS WITH GREAT SUCCESS].
Old Feb 14, 2006 | 04:45 PM
OctaneGuy's Avatar
OctaneGuy
Fine clear coat scratches can be removed by hand using ScratchX and a foam applicator pad. Proper technique is the key.
Check out this thread on my site and watch the video clip for a good primer on using ScratchX. I apologize it is a teaser for a DVD we are selling, but atleast the clip will give you a good start on where to begin. Most people use ScratchX wrong and don't have satisfactory results.
http://www.showcargarage.com/forums/...read.php?t=138
If you've got a Porter Cable dual action polisher, aka PC, then use that with a foam pad like the W8006 pad from Meguiars and a good paint cleaner like M80 or M83 and you will likely remove the lighter scratches. You might have to make 4 or 5 passes to get them out. If its too deep then you will have to use a rotary buffer and the same chemicals I just described.
I believe the Step 1 Paint Cleaner you are referring to is a chemical cleaner unlike scratchX which has diminishing abrasives--though I'm not 100% certain--I'm not intimate with all the Meguiar's consumer products, so I can't say for sure. If it IS a chemical cleaner, then applying it with a PC/orbital won't be effective since it's cutting action isn't dependent on a buffer.
I just posted a writeup of the steps I took to restore a 1965 Mustang. You can see it here. This was done using only Meguiar's products--no paint was added.
http://meguiarsonline.com/forums/sho...threadid=11040
BEFORE
AFTER
ORIGINAL: sowaxeman
Old Feb 18, 2006 | 10:04 PM
DJPACMANN's Avatar
DJPACMANN
hey...how do you get the scratches and swirls from the headlights? I have a 2000 MUSTANG GT...BLACK ON BLACK IN BLACK! NICE
Old Feb 18, 2006 | 11:11 PM
OctaneGuy's Avatar
OctaneGuy
Are the headlights glass or plastic? There are headlight detailing kits depending on the materials.
Plastic is easier to buff out and restore--glass is very hard.
ORIGINAL: DJPACMANN
BOB ROME
Jul 26, 2023 01:54 PM
jwog666
Dec 27, 2021 08:09 PM
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
Oct 1, 2015 09:29 AM
