I see spots.
Old Feb 20, 2006 | 07:03 PM
shayne's Avatar
shayne
Default I see spots.
I am a Stang owner, but my question is about my wifes car. She has a red ZX2 that was obviously never waxed until we hooked up. Now there are some spots on the hood and top that I couldn't seem to remove with Meguires scratch x ,their paint cleaner or polish. Does anyone have any ideas? Rubbing/buffing compund? I have a rotary buffer. Thanks in advance.
Old Feb 21, 2006 | 11:05 AM
mingrey01gt's Avatar
mingrey01gt
Default RE: I see spots.
Dillute some distilled vinegar and rub very lightly. If that does not work, try a clay bar.
Old Feb 27, 2006 | 02:33 AM
Rad Red 03's Avatar
Rad Red 03
Sounds like surface contamination, a clay bar will probably take care of it. Dont be afraid to keep rubbing with the bar, you cant hurt the clear coat as long as you keep it lubricated. After the clay, use a good polish, then wax. Good luck!
Old Feb 27, 2006 | 03:17 PM
shayne's Avatar
shayne
Thanks for the advice guys.
I got a clser look at this problem this weekend after installing some flourescent lights in my garage. I'm going to try clay first.
It looks like the clear coat is actually "pitted", like contaminants may have been acidic. If the clay doesn't work I have some Meguirs cutter that should do it.
BTW. After your advice and reading suggestions about clay on this site, I used it on the stang this weekend. That stuff is amazing. The stang is always garaged and kept well, but I was amazed at how clean the paint was after using the clay. Thanks.
I did the clay, cleaner, polish, tech wax, and ran out of time before I could yellow wax (this weekend maybe).
Autogeek
Mar 10, 2009 07:09 AM
Jefferson
Sep 9, 2008 04:48 PM
Gone2
Jun 26, 2006 11:22 PM
HRnB
Jun 13, 2006 01:35 PM
tbiker99
Jan 29, 2006 01:47 AM
