PDA
View Full Version : 4 Cylinder NA and Turbo
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16
  1. Injector Info
  2. hood pins
  3. does any one want
  4. 89' wont start, have codes
  5. Starting problems
  6. CAI in 2.3L...
  7. steering wheel, column
  8. Steering problems
  9. does anyway want....
  10. Weird sound/High idle
  11. Lowering
  12. ball joint control arm issue
  13. so f'in pissed
  14. buying a 4 cyl notch
  15. N/A dirt track Mustang for my 11 year old...for real!
  16. my 'vert in running good
  17. Posi?
  18. should i paint the car all black or .....
  19. Price estimates
  20. 93 LX 2.3 afew questions
  21. tranny screwed up?
  22. help me talk this guy out of destroying an svo!!!
  23. What engine? (update go straight to page 2)
  24. Charcoal Canister on a 91
  25. 2.3 Tech Articles
  26. T-Handle Shifter Removal 92 Mustang Convert.
  27. any1 have a timing belt cover 4 sale
  28. how do i count the gear ratio in rearend?
  29. Mileage
  30. Any mini stock racers out there?
  31. dumb question....
  32. 2.3 specs
  33. Strut Mount
  34. in the process of buying that 84 20th ann turbo vert
  35. couple 2.3L questions
  36. Just Bought a 92 Mustang...tranny fluid???
  37. Blinker fluid and broken muffler bearings????
  38. houston area car meet!!!
  39. Break Fluid?
  40. has anyone...
  41. general info on an 84 turbo gt vert
  42. 2.3 engine swap
  43. 2.3 Starter Swap Question
  44. EEC-IV code 334
  45. can i put straight pipes comin off my 2.3L
  46. tbird tc#2, complete car or parts avail, bringn it to ya again
  47. My new project car
  48. 2.3L stock radiators
  49. Got a line locker.
  50. any1 have a vacuum diagram?
  51. trading an '87 convert
  52. is there a way to make my speedo read correct?
  53. 2.3L code reader
  54. is this aftermarket 2.3 turbo intake worth it?
  55. Tune-ups
  56. fox body dash question
  57. Trade
  58. MOVED: Thinking of buying 67 stang
  59. Heater core for an '87 4cyl....
  60. Ignition Performance
  61. WIN TWO T-SHIRTS!!
  62. Need Some Help Here...
  63. Injector Harness Help please?
  64. EEC Identification?
  65. New transmission question
  66. would these weld rims look good in the front?
  67. Moved on today
  68. my car looks sick on turbo coupe rims, also t.c. parts for sale
  69. Transmission dipstick?
  70. '87 2.3L
  71. weird bolt hole, think im missing a sensor
  72. rear wheel base size
  73. 2.3L T performance numbers?
  74. pcv valve help
  75. I got new fuel system
  76. t-bird crossmember swap
  77. is this really a stock 2.3??
  78. need complete details ongoing n/a to turbo, need to know arerage cost involve too
  79. Tomorrow!!
  80. MOVED: just purchased a 2006 4.0L...need options on lowering car
  81. Weird Noise
  82. Transmission problems.
  83. So happy but PISSED
  84. 3" Exhaust
  85. anyone familiar with SVO performance, i need help!
  86. Transmission question
  87. Tranny Model
  88. burnout
  89. Got a new toy...
  90. Weird engine problem
  91. did i do the right thing?
  92. clutch swap
  93. Spark plugs
  94. Power steering switch??
  95. Remember the early 80's 5 spd 4 cyl?
  96. 2.3L cruise control
  97. 5spd
  98. Vacuum Schematic
  99. transmission shifts hard.
  100. we need stickys for pdf manuals
  101. 2.5l stroker build, whats needed, what can be expected??
  102. RPM Gauge
  103. RPM Gauge
  104. Hey Guy's Im Back!!!!
  105. 1991 Mustang Convertible 4 cyl LX
  106. WELL SHES GONE!
  107. pcv valve
  108. 2.3L T with carb...where is PCV??
  109. 1980 4cyl turbo 4 speed
  110. power locks
  111. Throttle body
  112. the turbo parts
  113. Check this out.
  114. V6 swap
  115. oil gauge?
  116. Upgrade
  117. Trying to Change Oil Need Help ASAP!
  118. I'm a new 4 banger owner*L*
  119. turn signals wont work!
  120. Overheating Engine, Coolant Fan Not Working
  121. NEED FUSE BOX DIAGRAM PLEASE
  122. What pistons?
  123. svo question
  124. whats cheaper/easier/better
  125. 2.3 help needed i want power now tell me how.
  126. 2.5l stroker
  127. Throttle Position Senor
  128. 87 Mustang LX
  129. Does anyone know who this is? Turbo Mustang II w/ T5
  130. Future Plans
  131. carbd 2.3 wont idle
  132. Fuel Filter
  133. NA 2.3l
  134. STICKY THIS!!!
  135. 2.3 to 2.3T Swap
  136. someone tell me is there such a thing?
  137. New just saying Hi...
  138. Check Engine Light 2.3L
  139. Add a turbo to a N/A or engine swap from Turbo Coupe?
  140. high idle rpms
  141. looking for this !!
  142. anyone looking to rebuild.
  143. 5spd.
  144. Flushing the system
  145. Need !
  146. wat does this mean?
  147. Need A Little Help
  148. cooked my alternator
  149. 2.3L turbo irradic idle
  150. i need an exhaust manifold if anyone has an extra
  151. What Do You Guys Think Of This 2.3!
  152. drivetrain
  153. Help with coupe trunk
  154. i think im on to something here.
  155. do i need...
  156. 2.3L Troubles
  157. What should I do? 5.0 or Turbo?
  158. what do you guys think.
  159. torque specs on 2.3 motor
  160. Help I need Help
  161. fog lights
  162. my turd still sucks, fan came on at cold start
  163. looking for a 2.3 stang
  164. Radar
  165. MOVED: parting out turbo coupe
  166. mhm
  167. Help please! Crankshaft stuck- then not!
  168. I have no idea
  169. Help? car will not start
  170. Trouble shooting codes
  171. turbo shut down
  172. oil change
  173. Emblems
  174. owners manuel / fuse diagram
  175. Suspension done! (sorta) pics! looks like ass
  176. 5.0 Throttle body?
  177. Temperature Gauge
  178. Few pics of underhood...
  179. a4ld
  180. does anyone...have
  181. name of tranny
  182. good cam for my turbo motor build
  183. High CO Reading in AirCare Testing
  184. WIN A FREE SHORTY ANTENNA!!
  185. I made a boo boo...
  186. Engine fan. Help!
  187. the new 4 banger section rocks
  188. intake?
  189. dash shorted out
  190. Swap To A 5.0...
  191. Installing a new gas tank
  192. the real reason i cant afford any car mods...
  193. Turbo oil feed line
  194. JUGGIE THIS IS FOR YOU
  195. Paint Job
  196. dont they...
  197. Carb.. to EFI... to T?
  198. HELP? car is shuting off
  199. transmission help...
  200. Auto to manual
  201. will the rims from a 96 taurus fit on a 89 lx??
  202. intake rotation
  203. Turbo Timer
  204. Ranger Rad in 93 Mustang?
  205. 2.3L Coupe Trunk Tortion Rods
  206. rim size?
  207. A/C delete?
  208. ride of the month voting
  209. 2.3L N/A to Turbo progress!
  210. what tranny do i have?
  211. Cheap 5 speed Transmission
  212. Has anyone ever seen two 4 cylinder mustangs race?
  213. 4 cylinder to v8 Swap
  214. anyone know disadvantages/advantages to a pcv valve with boost?
  215. 2.3 tech wanted
  216. 2.3 and V6 owners enter
  217. 4 cylinder
  218. Free CPU/Wiring Harness
  219. value of this car!!!
  220. quick tranny question
  221. Tail lights
  222. 1988 thunderbird conversion
  223. %^($ friggin timing belt!
  224. tHELP turd is ready to blow i think=new motor time
  225. what would it take
  226. mustang 2.3
  227. fatty tires
  228. ok i know u cant turbo a n/a 2.3l without trouble but can you s/c one and does anything exist to do
  229. enginr loses power and is very sluggish when its really hot out need help, this is my dailydriver
  230. airbubbles and white froth in radiator
  231. Custom Grind Cam
  232. suspension?
  233. 92 Problem
  234. if your looking for a nice 4 banger look
  235. 1990 2.3 Quit while Driving, won't start
  236. Best Mini Starter?
  237. AC Compressor 2.3l HELP!!
  238. multiple problems
  239. Well, I've Decided...
  240. 2.3L N/A to Turbo Buildup Help
  241. 86 svo
  242. 2.3 problems
  243. 2.3L Coupe Trunk
  244. Need Some Help
  245. 2.3 upgrades
  246. 2.3 turbo intake question
  247. What the heck is going on with my car?!?!
  248. Dead spot at low RPM?
  249. dont kno wat to buy
  250. Any auto cross or road rally 2.3 guys?
