Where to install sending units?
Old Sep 3, 2006 | 10:19 PM
Toddman0025's Avatar
Toddman0025
Default Where to install sending units?
Where's the best place to mount these suckers?
Water Temp
Oil Pressure
Old Sep 3, 2006 | 11:05 PM
Gun Jam's Avatar
Gun Jam
Default RE: Where to install sending units?
some intakes have a spot for water sending units if yours does then use it if not im not sure where it would go.
It looks like that’s a mechanical oil pressure fitting. I installed mine on the extension that the original oil sending unit screwed into. But on mine I wanted to use the original electrical sending unit too. So i unscrewed the extension from the block and drilled and tapped the extension so I could "T" in my mechanical pressure line too. Works great no problems.
Can send photo if you want.
Gun
Old Sep 3, 2006 | 11:10 PM
Toddman0025
photo would be great!
thank you!
Old Sep 3, 2006 | 11:22 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
make sure to route the hose nice and away from any exhaust manifold/headers otherwise ull get a smoke show
Old Sep 4, 2006 | 12:42 AM
Gun Jam's Avatar
Gun Jam
Hope this helps you with your oil sending situation
Works for me.
Gun
Old Sep 4, 2006 | 12:51 AM
Toddman0025
that is a HUGE help thanks!
what does the stock sending unit lead to - the dash?
Old Sep 4, 2006 | 03:08 AM
Gun Jam's Avatar
Gun Jam
yeah the stock unit sends the voltage to the gauge on the dash which I wanted to keep working when i installed my mechanical oil pressure gauge, so i just "T"ed my pressure line in as seen in the photo
Gun
cbird1177711
Sep 3, 2015 08:43 PM
amandahchase
Sep 3, 2015 10:09 AM
cbird1177711
Sep 2, 2015 08:51 PM
cbird1177711
Sep 2, 2015 04:12 PM
