need fuse panel info for 02
RE: need fuse panel info for 02
the fuse box is under your dash near your brake and clutch. if you take the cover off it has a diagram on the back side of it. i dont think your problem is a fuse though, these body style mustangs are known to have window motor shorts that happen randomly. i had a couple that did the same thing. i just held the button and slammed the door, it usually worked and if it didnt then you just hold the button down and bang around on the door panel and sooner or later you will find the spot and it will go up
jwog666
12-27-2021 08:09 PM
