mustang intake?
hello im new to this so bare wit me, im doing a rebuild on my 89 gt 5.0 302, i plan on doing the following, 24 lb. injectors bbk cold air intake upgraded mass airflow, ford f303 cam, ford hydraulic lifters, and bore the heads about 30 over with new pistons and rings, will the stock upper and lower intake be ok? Thanks
Hello, i have an 890 mustang gt 5.0 and wen i push my clutch down it goes a little bit and then just drops to the floor and the clutch is not being engaged, waht could be the problem, any help, thankz...
ok so my recent post was that im going to add the ford f303 cam 24 lb. injectors bbk cold air intake wit upgraded mass air flow sensor ford hydraulic lifters and the stock heads done 30 over, couple questions will the stock upper and lower intake be ok wit that setup?if not wat upper and lower intake should i look into and the 2nd question is wat size lifters should i get for plenty of clearance wit the f303 cam should i run 1.6 or 1.7 inch lifters, the f303 cam has a .512 inch lift with a 226 duration, and finally what pistons to buy if i need the clearance, any help thanx alot!!!
Mustangs of Illinois
Aug 22, 2015 10:00 PM
KEM Motorworks
Aug 14, 2015 10:13 PM
