WARM RUNNING COBRA
I have a 1995 mustang cobra with a temp problem. When the a/c is turned off
the temp gauge runs at the high side of normal (like at the a or l) unless I am
moving then its is fine. And when the a/c is turned onit runs a third or half way up(at the n ot the m). I understand that the low speed fan turns on at
221 degrees to keep the engine between 200 and 220 but is this a normal temp guage reading. I put a new 192 degree thermostat(stock) in and installed a fluidyne radiator.I runs very cool unless I turn the a/c off then the temp needle up to the high end. The fan does turn on but not untill it gets that hot! ANY INFO WOULD BE GREATLY APPRECIATED!
Nov 10, 2015 11:39 AM
Sep 8, 2015 06:25 PM
