Forum Issues and Feedback Discuss any issues you are having with using Mustang Forums here.
Clunking from front end
Old May 22, 2018 | 09:49 PM
Jmwjr1997's Avatar
Jmwjr1997
Default Clunking from front end
I have an 03 mustang v6, 3.8L engine 4 speed automatic, i have a clunking noise from the front end, i have changed the struts, the ball joints, tire rod ends, control arm bushings, sway bar bushings, engine mounts are fine, wheel bearing changed, the coil is a couple years old no corrosion on it, basically the entire frint suspension has been changed but still clunking/knocking but only when going over bumpy roads or turning.
my rear suspension is shot changing the shocks and coils in a few weeks, any ideas
Old May 23, 2018 | 05:30 AM
08'MustangDude's Avatar
08'MustangDude
Banned
All that, and no new end links? That's what mine has always been on my VWs.
Got the clunking over bumps now, and I know it's the end links...
Steering rack bushings?
Steering shaft coupler?
Old May 23, 2018 | 06:57 AM
GT Nate's Avatar
GT Nate
I'm gonna say sway bar end links, they'll clunk but appear fine when you take them off. Get new ones, easy DIY swap!
Old May 23, 2018 | 07:09 AM
Jmwjr1997's Avatar
Jmwjr1997
the steering rack bushing apear fine no cracks or wear and there appears to be no play in the rack
im new to working on my cars, steering shaft coupler?
Old May 23, 2018 | 07:10 AM
Jmwjr1997's Avatar
Jmwjr1997
ill have to give it a shot
Old May 23, 2018 | 07:14 AM
Jmwjr1997's Avatar
Jmwjr1997
If the cars is parked and i turn the wheel there is no nose, but if i bounce the car while its still ill get a clunk
Old May 23, 2018 | 09:03 AM
GT Nate's Avatar
GT Nate
make sure you jack the front up, then with another jack (maybe the one which came with the car) jack up the lower control arm until you take the tension off the end link. It'll take a torx bit and a wrench to undo it, reverse for reinstall.
Let us know how it works.
I'd use Motorcraft parts if they have them
Old May 23, 2018 | 02:33 PM
08'MustangDude
Banned
It can also be only ONE end link, and you won't know which one it is. When I took mine
off, I thought it was the driver side link. When I was taking off the passenger side one, and
the ball spun in the socket when taking it off with an air-gun, it was wobbling in the socket,
and the link moved up and down slightly. The driver side didn't do that. So it was the passenger
side one, but the noise transmits across the sway-bar. So, you have to replace them both.
racemyski
16
Dec 6, 2008 11:20 PM
Bmr4life
Oct 13, 2008 08:50 PM
Rubrignitz
Oct 27, 2007 07:04 PM
g0lden
Aug 23, 2007 08:34 PM
demarcom
Apr 16, 2006 11:41 AM
